Question about Apple iBook G3 Mac Notebook
IBook Clamshell Startup problem after Upgrade
I just replaced my clamshell G3 3GB HD with the 15GB Hard Drive from my iBook 3G Dual USB. It has System 10.3.9
I know it needs at least 128GB Ram to function and I only have the original Ram.
But I wanted to see if it would TRY to boot with the new HD. It does NOTHING when I try to start.  Like there is no power In fact, the power input that USUALLY lights up just by plugging it in, no longer lights up.
Did I do something wrong in re-assembly or is this what it does with insuficcient Memory.
I had sucess with replacing the HD on my iBook 3G Dual USB, and it is a lot more complicated that the clamshell.  BUT It's possible I missed something in re-assembly. I want to be sure before I tear the clamshell apart again. Thanks, Randall
    New Friend:
  • 4 Answers
Given that the "power ring" no longer lights up, I am wondering if the DC-in board is mis-connected in some way. No light = no power going to logic board, and no power going to charge the battery.
An alternative test would be to borrow a charged battery from another clamshell. If the machine boots, you know that there's something askew with the DC-in board.
BTW, there are excellent take-apart guides for iBooks at iFixit.com
Posted on Mar 25, 2008
We brought a used ibook 3g and it will not play the dvd's and the videos on youtube keep freezing and won't hardly play. What can we do to fix this problem?
Unless it is a SE (special edition) one, it will not play dvds - it only has a cd drive. Tangerine and Blueberry models do not have dvd drives. Indigo and Key Lime models do. there are 2 different graphite models - one does and one doesnt. And youtube videos never play well on clamshells - they weren't designed for internet video. However youtube mobile (m.youtube.com) does work on the clamshell i've found. Good luck!
Mar 28, 2010 | Apple iBook G3 Clamshell (M2453B) Mac...
Can I upgrade the operating system on the g3?
OS X 10.3 supports your machine... you may have problems if your hard drive is too small.... It looks like this OS will work with your G3 IF you have ample hard drive and memory..
Jan 17, 2010 | Apple iBook G3 Clamshell (M2453B) Mac...
Will the Microsoft Lifecam vx-5000 work with iBook apple?
The lifecam is compatible with 10.4 and 10.5. Your clamshell may be able to run 10.4 but it would need Firewire and 256mb of ram along with 15gb of free HD space. Then you'll need to get the CD or DVD.
Dec 12, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
I have ibook G3 running os x, installed. I been having problems getting the screen to start up and when it does the screen freezes a few minutes later.(the screen goes blurry or statically and stops...
It sounds like the system is corrupted. With an install disk try starting the mac up holding down the c key on the keyboard. If the screen is working properly on startup, see if the hard drive is showing up. If it is, try reinstalling the system software making sure that you do not reformat the hard drive but preserve users
Oct 10, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
I am purchasing a gently used Apple/Mac-G3 **** Shell I-Book off E-Bay, but I want to up grade the hard drive as well as replace the battery, so it can be charged through the A/C adapter. Where are the...
on the clamshell iBook the battery is directly under the back edge of the computer. right in front of the hinges on the bottom side. The hard drive will be trickier to replace because you'll have to take the computer almost all the way apart. If the computer doesn't come with the disks, YES, you will need some. Those can also be found pretty cheaply on ebay.
Jul 05, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Clamshell Ibook restore cd's I need everything
The clamshell ibooks came with either OS 8.6 or OS 9 on them. If you are just looking to start over from scratch, then you can use a standard OS 9 CD and have them do a complete re-install. I say this without knowing the nature of the problems they are having.
Jan 29, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
G3 clamshell ibook
Your Hard Drive is not booting correctly and most likely it is damaged. There are chances however that the data is OK, but will definitely need to be taken out to fix it. The best thing is to get a new HD for your Mac and start all over with installing the OS. That is if all the other parts are OK.
Jan 15, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
Replaced HD on ibook Clamshell, now can't boot
The Clamshell iBook 366 doesn't officially support Tiger, but can usually be installed using 'XPostFacto'. (You can get it here http://eshop.macsales.com/OSXCenter/XPostFacto/
It's open source software but you still might find some aspects of Tiger don't work.
Jan 12, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
M2453 mac clamshell Early 300mhz model has locked applications so I cant reinitialize hd and reinstall 9.2. Help! Firmware?
like the other person said,just boot from an os installer cd and do a clean install,it should completely wipe out any locks. when booted from the cd,go to the utilities folder on the disk and choose disk setup and reformat your hard drive,then do a clean install.
Jan 08, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
G3 ibook clamshell startup
The clamshell is 9 years out. The life of a hard drive under normal use is 4. Time to get a new machine? Does the clamshell have a firewire port?
May 04, 2008 | Apple iBook G3 Mac Notebook
Apple iBook G3 Mac Notebook Logo
102 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
