Question about Microwave Ovens
Microwave door removal
I need access to the door latch. How do I disassemle the door?
  • pr1v_8 Aug 07, 2008
    When pressing door key, the door will not open...it seems the spring is broken on the door key. How can this be fixed? Thanks.
    Problem Solver:
  • 11 Answers
The latch is fixed without any screws...it is fitted with a sensor that makes sure that the microwawe stops wen the door is opened nd starts only if it is closed
Posted on Feb 07, 2008
Door stuck shut. Pushbutton does not work. How can I get the door open for repair?
Jo. you may have to remove the hole cover, to access inner latch mechanism, where you can manipulate the latch with long screw driver.*** before attempting this, unplug microwave for an hour***
press the helpful button. link below may help...
Microwave Door Won Open
Jan 25, 2016 | Microwave Ovens
Hi, My Bosch built in microwave won't start when I close the door unless I slam it. I suspect the switch. Think so? Can I get at ithe switch to replace without removing the whole unit from the
You will need to remove microwave to access casing, remove casing and check door micro-switch. The switch activator will need adjusting to enable door interlock to activate.
Sep 29, 2014 | Bosch 500 HMB5050 Microwave Oven
Replace dor latch spring in Sharp Microwave R-1850A
Usually this can be done easily by removing the door unit and removing the panel to the door wherein you will be able to get access to the door lock. If there is no damage to the pivot or the post to hold the lock and spring , you can push the spring and reset.
Sep 03, 2014 | Sharp R-1850A Convection/Microwave Oven
GE Countertop Microwave Oven Door is stuck closed
Remove the cover. You should be able to access the two latches and release them. Once open you will have to take the door apart and repair the latch
May 05, 2014 | GE Profile Spacemaker Over-the-Range...
Plastic latches on door have no tension. Microwave thinks door is open, because latch is not ingaging. How do I access the latch hardware.
with butter knife or small flat head screw driver, carefully remove the plastic ring from ther inner door .cheap repair is to hook the spring to the metal fins inside the door if not order outer door panel
Jan 19, 2010 | Sharp R-1480 Microwave Oven
Replacing door latch on microwave
Remove the filler strip around the inside of the door for access to the latches. Eric
Sep 12, 2009 | Whirlpool MT4155SP Microwave Oven
The door latch has been pushed in so now the door can't close.
remove the outer casing so that you can gain access to the door locking mechanism, you will then have to use common sense to decide how to repair
Feb 26, 2009 | Microwave Ovens
Replacing door latch pawl
how do I replace door latches on a spacermaker XL microwave oven? thanks
Oct 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp Carousel Microwave R-1601
We have the service manual for the R1750-series ovens available at our Web site.
It's not exactly the same, but it should be generally close enough to help you.
It's at http://microwavedisplay.com/r1750_r1751_r1752_r1754_sm.pdf
Most door panels separate like the one in the example photo below.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 01, 2007 | Sharp R-1480 Microwave Oven
Sharp Carousel Microwave R-1601 - Need to Replace Door
It's at http://microwavedisplay.com/r1750_r1751_...
Microwave Ovens Logo
154 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
