Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Produce freezing setting is at its lowest and yet the produce still freezes. HELP ME!!!
The only true way to fix this is a kit Whirlpool/Maytag makes to resolve this issue and the only way I know to get the kit is have a fridge tech. come and order the kit and install it or call Amana and ask them for the kit if they even know which they should. Hit me back if any questions.
Posted on Feb 08, 2008
I had the same problem when one of my kids changed the setting of the chef's pantry (full-width drawer) to higher setting and everything started freezing. The setting should be at "lowest setting". Give it a try. deborah.
Scotsman icemachine constantly freezing up no matter how small you put the setting?
Max harvest cycle just keeps it in a harvest longer. if you set the freeze setting to its lowest point and ice is still to thick then replace the freeze stat.
Feb 22, 2015 | Scotsman Ice Machine, Cuber, 1930 lb....
Freezer not freezing
From what i;m hearing, i interpret the second lowest setting to be the second lowest refrigeration/freezer setting. Which means to me, and pardon my questioning this but, it means that the machine is not being asked to do any more than it is. If you turn the dial up, would that help? It really should say "cold" and "colder" or "coldest" on or around the dial. Please let me know if this helps.. Good luck.
Jun 29, 2014 | KitchenAid KSCS25FKSS Side by Side...
Maytag refrigerator
ea5703cb-9dae-46dc-802e-aff05e1adbe2.jpgYou may have defrost component failure. What is the model number of your Maytag? Sea Breeze
Apr 23, 2013 | Kenmore 50522 / 50524 Side by Side...
Crisper and veggie bins are freezing the produce
I have dealt with bosch and thermador quit a bit and they usually don't have to much of a recommendation for these settings because they are more of a commercial type appliance producer and all situations are different. Here is a tip for the sliders though. Remember that leafy produce needs more airflow to hold its texture and taste and anything with a skin requires less airflow. As far as the temp settings I believe the most nominal settings are going to be in between 5 & 7 to keep from freezing the produce. You will have to play around with it a little though to get it to keep the ref good and cold but keep from freezing the vegies. Hope this helps. Good luck.
Jun 05, 2009 | Bosch KGU6655
Frigidaire refrigerator freezes everything with setting on lowest
hello there,
try to check your thermostat setting adjust below gradually,
you set it up to coldest point that's why it's doesn't cycle on no auto shutt off and shut on,
if still not change for 12 hours still freezing up,replace thermostat by your technician,might defective.have a nice day
don't forget to rate me,thank's a lot.
May 05, 2009 | Frigidaire FRS26H5AS Side by Side...
Vegetables freeze in the vegetable drawer. Freezer is on lowest setting.
Make sure that you realise that 1 degree is colder than 2 degrees and therefore a setting of 3 - 5 degrees might solve your problem
Apr 14, 2009 | Refrigerators
Jenn Aire refrigerator keeps freezing food.
Your thermostat is faulty, pure and simple.
If the thermostat fails to do it's job, your compressor continues to run thus freezing your produce.
Feb 02, 2009 | Jenn-Air JCB2280HES Side by Side...
Crisper produce freezing
are they long times between door openings of the doors, this can cause cold air to migrate to the bottom of the fresh foor area and freeze produce
if this is not the issue, then turn down the fresh food control to a lower number monitor for 24 hrs
if this does not help replace the fresh food thermastat
May 20, 2008 | Kenmore 71812 / 71814 / 71819 Bottom...
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
297 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
