Question about OKI MICROLINE 320 Turbo Matrix Printer
Okidata 320 Turbo print head carriage slamming
The print head carriage on this printer slams into the left hand side of the printer, sometimes grinding its gears, whenever it goes back to the home position. Does anyone know how the printer senses the home position and what might cause this failure?
  • bbhats May 28, 2008
    I am having difficulty determining the obtical senser -- what does it look like? Where is it located?
  • Jack Butler Sep 25, 2008
    Bought 4 new oki 320 turbo in boxes. I didn't know these were 220v . Can I make these 120v? They have European type power cords.
There is a Optical sensor under the print head drive assy. You might have dust blocking this sensor.
Posted on Feb 14, 2008
Why is printhead suddenly slamming to the left?
Just drip a few drop of oil on the carriage rod. This might solve the problem.
May 03, 2014 | Kodak ESP Office 2150 All-in-one Printer
Carriage slams into left side
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Feb 22, 2013 | Lexmark Z600 InkJet Printer
Okidata 30 turbo carriage keeps running when reaches far left
Have you contacted OKI Data? Live customer support is available 24/7 (within the US and Canada) at 1-800-OKI-DATA.
Jan 27, 2013 | OKI MICROLINE 320 Turbo Matrix Printer
Microline 320Turbo 9pin
The problem your having is with the carriage assembly. You'll need to remove the ribbon and printhead. It's the black piece under them. Here's a link to a replacement part for $38.95.
http://www.str-s.com/okidata-turbo-carriage-assembly-p-716.html?manufacturers_id=6&osCsid=8849c8b4
Hope that helps you. :o)
Oct 14, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI Data Microline 320 Turbo
Suonds as if your spacing motor is going out. The part number is 56513701. Here's a link to a free complete Okidata Service Manual for your 320Turbo. The manual will walk you through the testing process to verify the problem prior to ordering the part.
http://www.feedroller.com/Store/Service%20Manual/SER320T.PDF
If this helped you, please hit me a fixya!. I'm just a tech trying to help people in my spare time.
Aug 29, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata - label printing alignment
The solution posted did not work for my problem. Thanks for trying.
Aug 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 320 Turbo -- Unclear characters in output
If it is not the ribbon, you may have to replace the print head.
Genuine Okidata Print Head
Mfr Part #:
50063802
Hope that helps...
Jun 21, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
C4180 printer
Hi ,
This product clearly needs a servicing as far as my experience goes . Still we shall go ahead and try to reach the solution or else this definitely needs servicing. I shall explain why -
1. check cartridge on right : if you have replaced the black cartridge and have been using the original cartridges then its an issue with the print heads. The black print head needs to be replaced by the local service centre . There is a blockage in the nozzles of the print cartridge that passes out the ink.
2. slam to the right : if i am not wrong this is the carriage you are referring to. Do the following steps (though i presume you might have done it if you have reset the printer)-
a. pull out the power cable
b. open the cartridge door and hold the carriage with your hand and move it manually 4-5 times left to right with as much speed as possible....there should be no obstruction on the way it moves.....if there is a pin / peice of paper / any obstruction - remove it if you can. The carriage could also slam if the pin of its movement has gone loose and it keeps on slamming uncontrolably. This seriously needs a servicing from the local service centre.
Apr 04, 2008 | HP PhotoSmart C4180 All-in-One Color...
Printing jibberish
Hello babytenbucks,
I can help you setup your Okidata 320 printer.
Connect the printer to the printer port coming off the motherboard. Usually it's colored pink. Also known as LPT1.
If your operating system is Win XP do this. Open Control panel, open Printer & Faxes. Click File, Add new printer.
Uncheck, automatically detect & install my plug & play printer.
Click Next. Allow it to use LPT1. Click next.
There are two windows here. On the left is Manufacture on the right is Printers. Scroll through Manufacture till you find
Okidata. Under Printer, scroll down till you see Okidata ML 320 Turbo/D (IBM), click next. You can give it a new name or leave it as is. Make the 320 the default printer. You can let it print a test page. Either way re-start the system. Try another test page.
Click the link below for a .pdf file which is the manual for your
Okidata 320 Turbo.
http://www.precision.com/manuals/Okidata_ML320_321_Manual.pdf
If you do not have Adobe's pdf reader download it from the next link.
http://adobe-reader.download-express.org/now/
babytenbucks, if your still have any trouble please just post back & we'll get it solved.
Good day!
& please vote...
Feb 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
1,038 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
