How to fax from lexmark f4270
I enter a fax number and then the machine says press start, which I suppose is the select button. Then it clears all data and does nothing.
Please advice me how I can fax from a lexmark f4270. What to press and when
  • 106 Answers
You must install a document for sending first,then dial press start
Posted on Feb 07, 2008
I HAVE THE X47850 SCANER HOW DO I SET THE SCANER CODE SO I CAN SCAN?
Hello.
You don't need a scanner code (pin ?) to scan. Here are the steps from Lexmark Support:
Step Action 1 Make sure the printer is configured to scan over a network. 2 Load an original document face down on the scanner glass. 3
From the control panel, press pattlnk_1182007_1150-uparrow.gif or pattlnk_1182007_1146-downarrow.gif repeatedly until Scan is highlighted. 4
Press pattlnk_1182007_1151-selectbutton.gif. 5
Press pattlnk_1182007_1150-uparrow.gif or pattlnk_1182007_1146-downarrow.gif repeatedly until the computer you want to scan to is highlighted. 6
Press pattlnk_1182007_1151-selectbutton.gif. 7
If you set a PIN during network setup and are being prompted for it:
  1. Enter the PIN using pattlnk_1182007_1151-leftarrow.gif and pattlnk_1182007_1152-rightarrow.gif to select a digit location and using pattlnk_1182007_1150-uparrow.gif and pattlnk_1182007_1146-downarrow.gif to select a value for that digit.
  2. Press pattlnk_1182007_1151-selectbutton.gif.
8
Wait until the printer has finished downloading the scan applications list. 9
Make your selections using the control panel buttons. 10
Press the green Start button (pattlnk_1182007_1144-scan%20start%20small.gif).
Hope this helps.
May 27, 2011 | Lexmark X4270 All-In-One InkJet Printer
Lexmark F4270 Fax machine
Plug another phone into the jack and see if it is a phone problem.
DickyO
Aug 19, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
REQUIRE INSTALLATION DRIVER FOR LEXMARK F4270 FOR WINDOWS VISTA BUSINESS EDITION
Go to the following website and enter your printer model (F4270) in the "Search by Model" box. It will then ask you to select your O/S. Vista Business is the same as Vista with respect to printer drivers. Vista 64 bit is one of the options, select it if you have Vista 64 bit. Otherwise try the XP driver
Aug 19, 2009 | Lexmark Office Equipment & Supplies
Drivers for lexmark F4270
You can get the drivers from here just scroll down and enter the code in the box then click download: Click Here
Jan 20, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
I have a Lexmark All-in-one X5490. Color Cartridge replacement request
Printable Version print_friendly.gif null.gif null.gif null.gif null.gif How to Clear the Memory on the Lexmark X4250 / X4270 ID:ENUS13874 null.gif null.gif null.gif
  1. Disconnect the power cable from the back of the printer.
  2. Hold down the Stop/Clear button.
  3. While keeping the button pressed down, reconnect the power cable. A message on the LCD will display MEMORY CLEARING.
    Note: The Fax, Copy and Scan buttons will remain ON until the message disappears. Only the Fax button should be ON when the function is complete.
  4. Select the personal settings you require as follows:
    LANGUAGE? Press the right arrow key to select the language you want to use, and then press Select.
    COUNTRY CODE: Press the right arrow key to select the country you will be using the printer in, and press Select.
    ENTER DATE: Using the date format dd/mm/yy (in the USA, mm/dd/yy), press Select.
    ENTER TIME: Using the format hh:mm, press Select.
    Select Format: Press the appropriate number to choose between 1=12hr, 2=24hr.
PERSONALIZE FAX: Press Select.
Enter Name: Type in the name and press Select.
Enter Fax Number: Type in the number of the phone line to which the printer will be connected, and then press Select.
Apr 18, 2008 | Lexmark X4270 All-In-One InkJet Printer
How can i download the CD software.
hi
you can get the drivers from here Lexmark X4270
select which o/p you are using and download them on to pc.
riz.
Mar 03, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Won't send faxes
did you put the originals page(s) in the machine FIRST to fax, then enter the number then press start?
If you enter the phone number 1st BEFORE putting your originals in the feeder, the machine thinks you want to make a copy.
The FAX Mode is the setting for incoming faxes.
Try that and let me know if it works.
There should also be a button called "Hook" or "speaker" or something that you hit and you will hear the dial tone.
Once you hear the dial tone, you can dial the number, (make sure the pages you want to fax is in the feeder.
Once you hear the fax high pitch noise, hit the start button.
Hope this helps.
Let me know if it does and also remember to leave a feedback and rating if I have helped you.
Thanks and good luck.
Mac =)
Feb 19, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Not able to recieve fax
Note u will be losing all our faxes stored in memory and contacts...
Feb 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270
HOLD DOWN THE SPED DIAL NUMBER WHEN IT BEEP THEN ENTER THE NUMBER WITH AREA CODE YOU WANT TO DIAL, WHEN FINISHED HIT SPEED DIAL AGAIN.
Oct 12, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Fax number
Press fuction 7 1 key in date & time press set
May 22, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
64 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
