Lexmark 29 ink cartridge
Can you reset these cartridges so the printer will use them after refilling them?
  • 1 more comment
  • Anonymous Mar 07, 2008
    you suggestion does not work !
  • Anonymous May 05, 2008
    Refilled but i kant to use...
  • Anonymous Jan 15, 2009
    i have refilled my cartrdge but need to reset it, how if possible. thanks
For the record the lexmark 29 (18C1429) cartridge is a one time use cartridge (return program cartridge). If you want to get a Lexmark 29 cartridge that you can refill you must buy the 18C1529 Lexmark 29 cartridge. This cartridge can be refilled and reused. The catch, you can only buy this cartridge from Lexmark.com new. I know of one company that sells the remanufacture Lexmark 29 (18C1529) yourinksolution.com.
Posted on Jan 28, 2009
    Sergeant:
    Champion:
  • 322 Answers
Yes you can go to printer and scanners bring them up and right click on printer and go through the menue you get ?
Posted on Feb 07, 2008
Ajkill
  • 2035 Answers
SOURCE: Lexmark x5470 all in one printer-low ink level
This is the problem because Lexmark cart have inbuild sensor , to by pass is to use original lexmark cart .
Posted on May 13, 2008
SOURCE: x5470 Lexmark printer
Just unplug the printer from the back and plug it back in. Problem solved. I did this on my mother's printer and it worked like a charm for this same error msg and issue.
Posted on Jul 07, 2008
  • 744 Answers
SOURCE: refilling cartridges
Joe,
You should have received control program software with your printer. If installed, the icon should be on your desktop or it may be in your programs list. You can also get the software from the Lexmark web site.
Anyway, you probably need to reset the cartridge using the control program. It's not difficult. Just follow the prompts.
Posted on May 16, 2009
ghassun
  • 499 Answers
SOURCE: how to reset lexmark36 ink cartridge
try to reset ur printer
press and hold on power button for about 20 sec then press hte power button again
Posted on Jul 25, 2009
  • 23 Answers
SOURCE: how to reset lexmark x4580 ink cartridge after refill.please help
http://images.lexmark.com/publications/pdfs/2007/3500/v2103618_en.pdf
Page 99-100
Posted on Sep 27, 2009
How can i refill 28 & 29 ink cartridges of lexmark z1320 inkjet printer
You can get a refill kit at walmart, but you can only refilled 2 or 3 times before the cartridges are considered to be non-usable anymore, and don't hold pressure or leak.
I would recommend using genuine new lexmark cartridges on lexmark printers for maximum performance and reliability (and quality) even though it is more expensive.
That's what the manufacturer recommends.
Good luck on getting new cartridges installed on your printer.
Jan 13, 2011 | Lexmark Z1320 InkJet Printer
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    I need to reset my ink levels so my X3550 refilled cartridges
    If you have refilled the cartridges you got along with the printer, you can't reset them. 23 and 24 are not meant to be refilled. They are what Lexmark call "return program cartridges"- they can't be refilled, you can send them back to Lexmark ( that's why they are called "return cartridges"). You need to buy either 23A and 24A or 34 and 35, those cartridges are refillable.
    Here is a link to Lexmark, with a list of cartridge compatibility for your printer:
    http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=x3550
    If you find my answer helpful, please vote. Thank you!
    Oct 22, 2009 | Lexmark X3550 All-In-One Printer
    Refilled ink cartridges at Walgreens, printer won't recognize
    Hello!
    28 and 29 are not meant to be refilled. They can physically be refilled, but they won't work. That is because Lexmark has put in a smart chip that doesn't allow refill.
    You need to buy 28A and 29A or 34 and 35, those cartridges can be refilled with no problem.
    Aug 05, 2009 | Lexmark X2550 All-In-One Printer
    Refill inkcartridge 17 of lexmark x2250 don't work
    “Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
    Apr 28, 2009 | Lexmark X2500 All-In-One Printer
    Refilled the black cartridge and now it doesnt recongize it
    Apr 13, 2009 | Lexmark X5650 All-in-One InkJet Printer
    Is it possible to refill ink cartridge on Lexmark x6690 printer?
    Take out all cartridges, switch printer off and then on again and let printer see that there are no cartridges. Do this 5 times, it resets the cartridges. Then install refilled cartridges
    Apr 08, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
    Lexmark 5070 printer
    Hard to tell...There are other issues which could contribute related to the printer itself, etc.
    But I will say in my experience often refill kits for ink cartridges don't work if you allow them the cartridge to run bone dry. Maybe the internal components become hard and won't re saturate with new ink, not sure. If new cartridges work; and the refills don't I'd say there may be a problem with them.
    Jul 22, 2008 | Lexmark X4270 All-In-One InkJet Printer
    2,498 people viewed this question
    k24674
    jasbo
    jasbo
    Marvin
    Marvin
