i hooked the head and amp up no problem. It sounds great except there is
a beating noise coming through the speakers even after i turn the key off. it wont stop until i turn the amp off?? I turn the radio up and it drowns out the beating noise? this is on an old motorcycle. What is causing this?
Comments:
Feb 07, 2008
- I installed it exactly the way the the instructions said. Is this a manufactors malfuntion or an installation issue
Feb 07, 2008
- my amp is making a beating sound through the speakers even with the key off. There shouldn't be any juice. I hooked everything up according to the manaul.
Hi the problem you are having is inteferance from the servo on the bike this is causing a voltage spike and this is giving you the clicking noise you hear you can try buying an inline filter this should filter out the noise for you give it a try but you should find this solves you problem let me know if you need further assistance
Comments:
Feb 07, 2008
- if the sound happens when the key is off then it is wired up to the wrong positive wire it needs to be an auxillary wire not a wire that is live when the key is off this will cause problems as the voltage might differ slightly if the wire you are using is for something that uses alot of power but even so an inline filter should filter out any interferance your having. Also check the earth on the earth wire is good conection where it goes to earth out on the bike as this can also cause you problems make sure speakers are wired correct also as this will affect sound quality let me know if you need further assistance
Feb 07, 2008
- You could even wire the positive feed onto something like a light that comes on like a warning light any other light thats on your igntion when you switch the key on doing this will stop the unit working when the key is turned off because the last thing you want is flat battery
Rating Locked! (?) ottome has rated this solution as Very Helpful
i have a pyramid crystal 2ch mosfet amplifier with 1600w for my car and i connected everything right...
(More)
i have a pyramid crystal 2ch mosfet amplifier with 1600w for my car and i connected everything right and the red protection light will not turn off. i tried it on a friends car and i still had the same problem. I have had the problem for about half a year. What can i do to fix it? Anything will help. Thanks
i have a sony explod cdx-gt480us. when inserting a cd, it does not play, the power shuts off and on...
(More)
i have a sony explod cdx-gt480us. when inserting a cd, it does not play, the power shuts off and on and off and on. the unit is brand new and ive tried different cd's.
