Question about Clarion DB175MP CD Player
Clarion DB175Mp memory wont stay set car is turned off
  • Anonymous Mar 20, 2014
    looking for a diagram for a Clarion Car stero for a DB175MP
There shoush be a red wire and a yollow wire the red goed to accessory power and the yellow goes to constent power what is i did is ran it to the fues box and wired it into the cargo light then after that it worked fine i hope i helped
Posted on Feb 08, 2008
It says amp guard when i turn it up
Sounds like you have speakers that are wired incorrectly. Most car stereos require a 4-ohm load, if you wire two standard speakers in parallel it will create a 2-ohm load and cause this condition.
Jun 28, 2010 | Clarion DB175MP CD Player
I need help getting my radio to turn on after i got a new battery
I assume you checked at the fuse block of the car. If the radio is aftermarket also check if it has has a fuse or maybe 2 fuses at the radio. They might be in fuseholders from the hot wires of the radio.
Jul 27, 2009 | Clarion DB175MP CD Player
Just need DCP storage box and bluetooth adapter
I found a generic storage case for my faceplate but not the bluetooth adapter. Thanks anyway
May 19, 2009 | Clarion DB175MP CD Player
Wiring diagram for cd player
that actually is not for a head set, tha tis for a remote, you plug in the remote that you can buy from an audio store and mount it on the dash....
Nov 26, 2008 | Clarion DB175MP CD Player
Antenna Power supply
First order of business is to check and see if the antenna is operating properly. If the wire in your harness is intended to power the antenna, connect 12 volts to this lead, and the antenna should go up (this needs to be done with the key in the ON or ACCY position). If the antenna does not go up, check the fusebox for a blown fuse. If the antenna does indeed go up, then you can scratch that off the list of possible problems and move on to the next step.
The Clarion should have a power input wire to keep the clock alive, and a power wire (normally of heavier guage) to actually power the radio. Make sure the radio operates when the key is in the ON or ACCY position. If the radio is operating, so far so good.
I'm kind of confused when you say there are two wires on the clarion... "power antenna turn-on" and "auto antenna". Are these both on the clarion? There should be a wire that constantly feeds the antenna with power (I would cal this one auto antenna). It should always be powered to 12 volts. The antenna should operate when the "antenna turn on" lead becomes 12 volts. Normally this ONLY happens when the clarion RADIO is on (ie: if you're listening to a CD, the antenna probably won't get activated).
After checking all this, if you're still having problems and if you haven't already done so, grab a DC volt meter and verify that the clarion power antenna turn on lead goes to 12 volts when you turn on the radio. If it does not, then there is an internal problem within the radio. If this lead IS going to 12 volts when it is supposed to and the antenna still isn't working, then my guess is that the antenna is malfunctioning.
Let me know what you find out... I'll keep looking at stuff from this end. Good luck.
Apr 19, 2008 | Clarion DB175MP CD Player
Clarion DB175 cd player
The Clarion manual lists 3 error messages.
Error 2-A disk is caught inside the CD deck and is not ejected.
Error 3-A disk cannot be played due to scratches, etc.
Error 6-A disc is loaded upside-down and cannot be played.
Good Luck.
Mar 26, 2008 | Clarion DB175MP CD Player
How to set the clock on a clarion DB175MP
http://www.clarion.com/us/en/products/2007/audio/source_unit/CD/DXZ275MP/us-en-product-pf_1165294998468.html
Go the link shown above. On the right side of the screen, you'll see a button to download the product manual. Download the manual in PDF form, and go to page 19 where you'll find the step by step on how to set the clock.
Normally I'd write it out for you, but there's a lot of symbols to describe the buttons, and the information is copywrited. At least you'll have the manual.
Mar 14, 2008 | Clarion DB175MP CD Player
NEDD TO KNOW HOW TO WORK THE FADE CONTROL
Press the <<,>> button and select "Fader".
Turning the Rotary knob clockwise fades the sound to the front; turning the knob counterclockwise fades the sound to the rear speakers.
The display changes as follows:"Front XX" will be displayed where "XX" is the value from 1 to 12.
"Rear XX" will be displayed where the "XX" is the value from 1 to 12.
When fader is 0, "CENTER" will be displayed.
Jan 04, 2008 | Clarion DB175MP CD Player
Clarion DB175MP CD Player Logo
252 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
