I have a DVD-1600 player and the remote control stopped working. I have replaced the batteries and tried carefully directing it at the remote control sensor as the trouble shooting guide suggests but no response. (I have unplugged the player and plugged it in again.)
  • 98 Answers
Replace parts "infrared diode" from ur remote control..
check polarity of infrared diode "anode-kathode"
Posted on Feb 07, 2008
Remote has stopped working. Can it be repaired or where can I find another one to replace the broken one? We have changed batteries multiple times. Thanks!
Yes, it can be repaired, one common fail is that the keyboard is dirty inside, try to open carefully the remote control, sometimes it only has one screw or none, the rest are plastic clampers located on both sides, you can use a plastic knife to try opening, after that you can easily remove the pad of keyboard and clean it with water and neutral hand soap, the electronic board can be cleaned with an alcohol wet cotton, if all this doesn't work there's an electronic component failing and have to be replaced.
If you want to avoid the former procedure you can get a universal remote control compatible with your DVD/VCR combo.
Mar 01, 2011 | Samsung DVD-V4600 DVD Player/VCR
Remote stopped working
clean the circuit board on the remote moisture might be the problem
Aug 14, 2008 | Philips DVD750VR DVD Player/VCR
Remote control has stopped working
If you have replaced the batteries with KNOWN GOOD ones, observed the proper polarity when re-installing the batteries AND made sure the remote is in DVD "mode" (if it is a multi-remote) when trying to use it, the remote is bad. Replace the remote.
Mar 25, 2009 | Panasonic DMRES15 DVD Recorder
Where can I purchase a remote for the dvd-1600 mintek?
You can purchase a replacement remote at the link below, for $27.99:
Mintek Replacement Remote Controls
An universal remote will work, but the codes may not be available. That can be a complication as you need to go through the remote programming procedure manually.
Better to buy the original replacement.
Feb 28, 2009 | Mintek DVD-1600 DVD Player
Does not respond to remote control
After power on the dvd, open the tray and put any video dvd in and close it, wait for about a minute, then press Setup or any button on remote control, if it work then need to replace with the new battery CR2025.
Jan 27, 2008 | Cyberhome DVR 1600 DVD Recorder
Remote control
try the most economical solution first replace remote with a universal one purchased at walgreens or walmart.
Think about it remotes fall after being put down they are handled by llittle ones and overall they are used more than the actual buttons on the dvd player
Jan 14, 2008 | Mintek DVD-1600 DVD Player
Remote control
you can find a replacement at cyberhome store nearest you.
Jan 07, 2008 | Cyberhome DVR 1600 DVD Recorder
Dvd player stuck in 'demo repeat mode'
press and hold the power button for about 5 seconds to reset the player
Aug 13, 2007 | LG DN798
Remote control will not work?
Hi Quad, recently I also got same recorder and faced the same problem with the remote controller. today i tried to solve this. i opened it up. it turned out the battery connections are not proper. The battery connection are in the form of a spring coil which touches the outerside of the battery which is not touching properly. I bent and slight lift it with a plier and it started working. The other connection is touching front side of the battery(on backside you see label cr2025 printed) and this is alright. I hope it works for you too. with best regards
Nov 26, 2006 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
184 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
