Question about 3Com OfficeConnect Wireless 11g Cable/DSL Gateway Router (3crwe754g72-a-uk)
Can't connect to 3Com Office connect wireless from Apple Mac Pro
My laptop cannot find the PPPoE connection.
  • Ronen
    Ronen May 11, 2010
    do you mean it can't find the wireless network?
I can't connect to 3com network from my laptop.why?
Posted on Aug 18, 2008
  • 86 Answers
PPPoE connection is set up
1. Control Panel, double-click Network Connections. 2. Click the PPPoE connection under the Broadband group that you want to share, and then click Change settings of this connection under Network Tasks. 3. On the Advanced tab, click to select the Allow other network users to connect through this computer's Internet connection check box. 4. PPPoE connections behave in a similar way as do dial-up networking (DUN) connections, and you may want the connection to be automatically dialed when another computer on your network attempts to connect to the Internet. To do this, click to select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box. 5. If you want to allow other network users to enable or disable the shared Internet connection, click to select the Allow other network users to control or disable the shared Internet connection check box. 6. Under Internet Connection Sharing, in Home networking connection, click the LAN (Local Area Network) connection that connects the computer that is sharing its PPPoE Internet connection to the other computers on your network.
Posted on Jun 07, 2008
SOURCE:
I cannot connect to my 3Com OfficeConnect Wireless (3crwps10075-us) Print Server 3crwps10075
Check you firewalls. Sometimes you will have to allow certain mac addresses or certain ip addresses (may be less secure than the mac address), then change sharing level to full, before things begin to work.
Please post back and let me know if this helps!
Feb 21, 2012 | 3Com OfficeConnect Wireless...
Cannot connect to internet, safari unresponsive, wireless good, airport on. macbook pro
You need to check whether ISP is working ok. To do this, connect your Mac Pro direct to your ADSL modem and see whether you can connect. If so, your Wireless may be too congested. Try to use a free WiFi scanner to check others who are on your channel. If you cannot find a clear channel to use, you may need to use another freq band AP, normally they are 2.4G WiFi, you can now use the 5.4G WiFi. You Mac Pro should support this band.
Mar 30, 2011 | Apple MacBook Air
Laptop running 0n win 7 wont connect to router
1. you will have to designate the laptop or allow it to connect by entering it into the 3com router.
2. try connecting to the router via ethernet cord (that is connecting with a physical straight through cord) that came with the router.
If connected with this then you will have to go into the router via the IP set 192.168..0.1 depending on the router ip for loging in.
2. Go to the "wireless setup" and enter your MAC address for the laptop in the permissions list in the router. Instructions on how to do this is at the manufacturers site. Step by step.
3. Do the following step if instructions not found.
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP adresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jun 19, 2010 | 3Com OfficeConnect Router
Struggling to connect my MacBoo pro to a printer connected on PC
is the printer connected to a router or base station wirelessly?
Jul 08, 2009 | Apple MacBook Pro Notebook
Router problem
try to disable any firewall you have, disable windows firewall if its enable and try to lower your Internet Security or use default if set to custom.
Nov 24, 2008 | 3Com OfficeConnect ISDN Lan Modem Router
Wireless connections
Please you write more detail to problem.
Thank you.
Mar 27, 2008 | Computers & Internet
Can not connect wireless router
Try resetting the router to factory defaults.
Dec 26, 2007 | Apple MacBook Pro Laptop Computer with...
USB modem cable quandary
i am new too --may this trigger more people to help
from my limited experience
yes u need a NIC card in your pc
isp signal--->isp modem---->rj45 cable---->wireless (switch/access point/ Router--->NIC(PC)
---->wireless adapter (notebook)
----->wireless adapter(PC)
nowaday with a Gigabit Nic
u can match 802.11b 11mb/s
802.11g 54mb/s
802.11n 300mb/s
i use verizon at first with PPPoE
later Comcast cable dynamic
u need to go to web site ip address assigned by DHCPof your 3com wless router to make sure or/and clone the router so that it has same MAC addtress as your NIC of your PC before u can get CONNECTED with the Web----(u can see the green display on the upper right of the screen of the router page after u get connected) dl
Dec 25, 2007 | 3Com OfficeConnect Router
3Com OfficeConnect Wireless 11g Cable/DSL Gateway Router (3crwe754g72-a-uk) Logo
1,393 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
Mike
Prashant M
Prashant M
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
