Question about Whirlpool LSN1000LW Top Load Washer
WASH MACHINE IS LEAKING GEAR OIL ON FLOOR AND WON'T SPIN THE CLOTHES OUT
For the las two week my wash machine has been asking up and hasn't been spinning my clothes out like it used to. Last night we took it apart to see if any hoses were clogged up and some of them were, but that wasn't the problem. Then we noticed that there was gear oil all over my floor where it has been leaking. Can you please help me? My washing machine is a
model LSN2000JT2, S/N CM2603036
I was washing all white clothes. I pulled out my clothes and noticed little black spots all over the clothes. Upon further inspection their was oil coming out from underneather the agitator. How can i get this oil off my white clothes? Please help. Thank you.
Posted on Sep 29, 2009
  • 57 Answers
If the drive block was pushed in to far into the transmission it will damage the seal causing it to leak.
Posted on Feb 16, 2008
  • 283 Answers
Oil spills on that design are almost unheard of. See if it's still covered under the warranty. if not it's possible to repair it cheaply but more often than not it's more practical to replace the machine especially if its had a lot of use
Posted on Feb 07, 2008
  • 552 Answers
If there is oil leaking out, you may have a leaking gearbox.
There is nothing you can do about that but replace the gearbox.
Here is a website link for parts.
http://www.theappliancepartswarehouse.com/seo_indexing.html?m=Whirlpool&s=18500
you can copy and paste this in your web search window
Water leaks from underneath my top load washer
Could be pump with motor.I replace on mine,had water under.
Apr 12, 2013 | Washing Machines
My figidaire pauses after two or three minuets
Hello.
what you need to do to solve the problem of the washer is to troubleshoot below are step by step solution on how to solve the problem.
If your washing machine is out of whack, check for these easy fixes
before you spend money and time on a repairman.
1 Make sure the cord is plugged in and that the breaker hasn't tripped.
2 Reset the overload switch - according to the manufacturer's directions - if the machine won't turn on but the breaker hasn't tripped. (Make sure you take some of the clothes out before you run it again or you'll have the same problem.)
3 Check the hot water faucet if the water isn't warm. Also clean the filter screens and make sure that your hot-water heater isn't out of hot water.
4 Make sure the faucets are on, the filters are clean and that the hoses aren't kinked if the washer is filling too slowly.
5 Clear any obstructions in the hose if the clothes are too wet at the end of a cycle. Also, be sure the washer is spinning; if it isn't, remove some of the clothes and redistribute the load. Reset the overload switch. Tighten the drive belt if this doesn't fix the problem.
6 Check the hoses for damage if you are seeing water leaks on the floor.
7 Put a nylon stocking on your hand and feel around the inside of the washer if you are finding snagged or torn clothing. Sand rough spots with fine sandpaper.
Thanks.
Nov 13, 2011 | Frigidaire Washing Machines
Piece of clothing caught in spinning wheel
Hello, you a side load washing machine. The spinning wheel is a counter weight for the wash tub.
The tub out seal that fit around the tub is worn out. News a new seal. Unplug the washing machine and remove from cover with the door. Once you have the front panel with the door the tub seal is attached to the front by lock clips. Remove the clips or screws. Now, check the interior seal and make sure does have any hole in it. If there is holes then walter will leak on to the floor.
You might have to use a Laundry Mat for a few week while waiting for parts. GB...stewbison
Sep 10, 2011 | Washing Machines
The belt is soaked with oil, the spin cycle only goes about half speed and the clothes are still soaked when I take them out. There is a large puddle of oil on the floor under the machine. Help, what kind...
you got a leak on the centre pole water in transmission get some degreaser wash the belt and spin clutch till you replace the machine repairs to costly
Jun 09, 2011 | Washing Machines
After washing -washer slowly fills with water and runs out the door--not every time it is used. First noticed clothes still wet needing to run spin cycle--then washer leaked on floor over week end and...
I would suspect the water inlet control valve may be malfunctioning- not closing (its default no power position).
Quick temporary fix, although tiresome, turn whichever tap, hot or cold, off when washing finished. You've probably already thought of that!
In the meantime I would suggest a service call is required ;-0(
John C
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The clothes are still wet after dry cycle is finished
Lift the washing machine and look underneath. Inspect the bottom of the gear case for evidence of oil. If oil is present, the oil may have leaked onto the spin clutch causing it to slip during your final spin. The transmission and clutch may need to be replaced.
Dec 19, 2010 | Washing Machines
Hi! GE top load washer model number wwse5240 is leaving grease stains inside the machine after laundering and of course on clothes. Not sure how old this machine is.
Your transmission is leaking oil. It's probably 10 to 15 years old for the transmission to be leaking. It can be replaced but it's not a small job. Part 320 in this diagram is your transmission. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5224109&diagram_id=22255027#d22255027
Jan 30, 2010 | GE WDSR2080D Top Load Washer
Washer washes clothes.spins but when removing clothes they are soaking wet..machine will spin but doesn't remove all water from clothes
Check the belt. If you have an oil leak also it is time for a techo to do a service on the machine.
Oct 18, 2009 | Washing Machines
Won's spin
We have not heard back on this in about a week. I'm presuming It's been repaired?
Jun 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Roper washing machine
It's direct drive. It may have a bad coupler. Did you see any black particles under washer? Also look for oil on floor and bottom of washer. Transmission can leak oil into clutch causing slow spin.
Nov 11, 2007 | Washing Machines
Whirlpool LSN1000LW Top Load Washer Logo
888 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
