Question about Sony PlayStation 2 (PS2) Console
Ps2 power not working
My ps2 power doesn't work when i set it up. before i used to just jiggle the power cord and then it works but now it's not working.
    President:
  • 4,402 Answers
Try a new power cord other wise you either have a connection bad on the inside or a blown fuse.good luck
please mark the post with a fixya!
Posted on Feb 07, 2008
Video problem
I had a PS2 with a similar problem. your best bet is to find another cord and try it with your system. (Sometimes the cords just play out).
You said your screen is blurry though so it is most likely a bad connection between your cord and the port on your TV.
Lastly if you can\'t find another cord to try you can attempt to clean your own with a Q-tip and rubbing alcohol.
Unfortunately if that doesn\'t work then your looking at problem with your motherboard. At that point your better off to go buy a still working PS2 then have your own fixed.
good luck
Mar 28, 2014 | Sony PlayStation 2 (PS2) Console
I have a playstation2 -slim and when i turn it on the screen is black and white and the picture bounces up and down
Try it on another monitor / tv - if the problem happens there also, send the playstation in for warranty repairs or service.
most likely a fault in the video circuits, or possibly bad cable, you could try another cable first.
Jul 25, 2008 | Video Game Consoles & Games
Can't turn it on. Power digital readout doesn't work.
Mine would not turn on at all, found the contact pads for the buttons was corroded. Used an eraser and cleaned them, working good now. Of course the whole thing has to come apart to get to the contact pads.
Nov 30, 2011 | Bemis 821 000 Humidifier
When i turn on my ps2 the power doesnt work but i already change the fuse
It might not be the fuse,it must be its power cord or the plug you are using try that if it works on other plugs and if not, check the power cord(cable).
Oct 06, 2011 | Sony PlayStation 2 (PS2) Console
Have not used my Garmin since January 2011. Sitting on shelf. Plugged in to my car charger and would not turn on. Would this mean it needs charged?
After three months, I'm sure the internal battery needs to be charged. But even so, it should work when plugged into the car charger. The first thing you should do is check that the charger cord is connected properly at both ends. Mine has a green LED on the plug. If yours does, make sure that light goes on. Try jiggling the connectors at each end of the power cord. If it still doesn't work, the next thing to try is replacing the power cord. (Maybe you can borrow a power cord from a friend). If the power cord isn't the problem, I'm afraid the problem is in the Garmin itself. Good luck.
Apr 18, 2011 | Garmin nuvi 1490T GPS Receiver
The toaster does not heat and it's only 6 mos. old.
1. check outlet where you plug in your toaster with lamp or vacuum.
jiggle plug of lamp or vacuum while plugged in to check for bad outlet.
if lamp or vacuum do not work, check breaker panel/fuse box for tripped breaker/blown fuse.
if breaker/fuse okay, replace outlet.
if lamp or vacuum work okay, go to next step
2. plug toaster back into outlet, jiggle plug, then jiggle cord at plug, then jiggle cord at toaster.
this checks for intermittent power cord.
if cord okay, check that the toaster lever or toast basket are not blocked from going completely down.
might be a bit of bread, muffin, bagel that blocks the basket.
if all okay, you need other solutions.....
Jul 09, 2009 | Back to Basics Kitchen Appliances - Others
Ps2 controlelr not working
CHANGE U R CONTROLLER CORD it will be ok
Feb 01, 2009 | Sony PS2 Dual Shock 2 Controller...
Re:power a/c cord for pacific digital
if you have the power supply aka the brick and just need the cord from the brick to the wall, a PS2 power cord works just fine! I found that out by accident, but since PS2 is very popular chances are you can find one at any store or on ebay. from the brick to the round post on the back of the device, I don't know about that one...but if you just lost the one piece..the PS2 works fine
thanks,
Mar 01, 2008 | Pacific Digital (U30274) DVD±RW...
Power failure lense
Try to unplug the power cord and plug it in and if that dont work you got a short in your power cord your ps2 is messed up............or there is a problem inside your ps2.....there you go thats all i got on that..................****
Jan 24, 2008 | Sony PlayStation 2 (PS2) Console
Slimline PS2 Power Problem
What do you have to hold down, the cord from the adaptor to the machine or the cord from the plug to the adaptor? Did you get a shock when you first tried holding the cords down? The cords are pretty thick and the insulation should not peel off at all unlees you are also twisting the cord. Also if you lay the console flat instead of using the stand the problem may clear up, because you won't be twisting the cord.
Sep 20, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
