Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
My freezer section of an LG frech door is not getting cold enough.
i emptied the whole fridge. unplugged it for 24 hrs and ran it back up. The air comming from the frezzer section vents in teh back just doesn't seem to get cold enough. Is it stuck in defrost mode? Do I have a refrigerant leak? Can any one help please
  • 1 more comment
  • Anonymous Apr 24, 2008
    I have the same problem with my LG LRDN20724TT bottom freezer. It's only a couple of years old. It doesn't get cold. The compressor would come on for a few seconds and go off. I had a tech guy over who replaced the starter relay, but it's still not working. The compressor is working but nothing is getting warm or cold. He came back today and said it needs to go into the shop and probably has a freon leak or a broken compressor. If it's the compressor he said I might want to buy a new refrigerator as it will likely cost me $500 to $600, or if it's a freon leak it will cost $250. I've already paid him $150 to change the starter relay, and he wants another $100 to take it into the shop to find out what the problem is if I don't get it fixed.
    I'm wondering which way to go. It's a stainless steel appliance and probably worth $1500 new. Any suggestions would be appreatiated.
  • Sandon Apr 24, 2008
  • Anonymous Mar 29, 2014
    refrigerator is cold but freezer not cold enough Cold air blowing in freezer but not cold enough to keep things frozen There is a sound like it is running but it never stops - no on-off sounds. I cleaned dust off coils in back. I felt fan blowing semi-cold but not super-cold air in freezer section. Fridge half is working perfectly
  • 92 Answers
You would have to take the back wall of the freezer of (after it has been running a while) see how much of the evaporator is frosted up if none freon leak or bad compressor if just a little on top then a restriction. if you open it and the whole top above the evap is a huge chunk of ice i would try a dryer filter(its part of the sealed system)
Posted on Feb 10, 2008
GE( 2-door) ref portion door left open the whole night,it's not working now except the freezer. Tried unplugging it for 24 hrs, but still not working.
the air ducts could still have ice in them,remove the bottom kick panel,you should find a tech sheet either on the kick panel or taped in the cabinet area down there and it will tell you how to manually put your fridge into defrost, you don't want to work on it while it's running or you'll make it worse,you'll know it's in defrost when the compressor shuts down and the fan in the freezer stops blowing if you can't find it shut down the fridge or unplug it again,remove the food from the freezer,if you're handy remove the back inside wall of the freezer and with a hair dryer melt out any ice up in the vents and blow the air from the hair dryer up above the fan motor and in the corners, ,you'll see water dripping where the ice is,heat it up until no more water drips down,hit one side for a few minutes and then the other side for like 5 minutes at a time so you don't damage anything from heating it up to much,or if you have another fridge leave it unplugged for a couple of days.if you can't remove the wall blow the air into the air slots in the back wall panel,in the right and left side corners and then in the middle,have a light or flash light,you should be able to see water dripping down,keep blowing the air in until no more water is dripping,might take you like 30 to 45 minutes to do this,then turn it back on and see if you can feel cold air blowing into the fridge section,if not shut it down and heat it up again,if you see water dripping there's still ice in there,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air up nto the fridge section and the air returns to the freezer through the air ducts,when the door was open warm and cold air meet and forms ice in the air ducts,if the fan is working and depending on your model and next time you write send the model number you could have a damper it could of got damaged but it sounds like all you have is frozen air ducts
Aug 25, 2012 | GE Refrigerators
The freezer component is frezzing continuously.
This problem is related to defrost.
Try manual defrost reset procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced. you can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------
If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.
This will help.Thanks.Helpmech.
May 16, 2011 | Kenmore Side by Side Refrigerator
Freezer works refrigerator is warm
If the freezer is getting cold and working properly, but fridge section is not getting cold, then it can be defrost issue.------------------ The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.--------- Try manual defrost reset procedure: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.This should help.Thanks.Helpmech.
Apr 28, 2011 | Amana Easy Reach 20.5 cu. ft. Bottom...
THe fridge on our fridge freezer isnt working
If the freezer is getting cold and working properly, but freezer is not the it can be defrost issue.------------------ The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.--------- Try manual defrost reset procedure: ----
Apr 27, 2011 | Refrigerators
I hava a 2 door fridge, the front of the freezer has a little ice and the bottom really is not getting cold
It can be defrost issue.First try manual defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. -------------The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.----------- The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
Apr 26, 2011 | Whirlpool ET1FHTXM Top Freezer...
Freezer is not getting cold not sure if it is stuck in defrost mode
Freezer not getting cold, then defrost problem is rare, it can be compressor issue.If freezer getting cold but fridge not getting cold, then yes it can be defrost problem. The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.---------- But in your problem, you mentioned, in that freezer section is not stating cooling.So the compressor can be the issue.But still try reset procedure and see, if that is helping. Try manual defrost reset procedure: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If still the same problem, then the compressor has to be inspected.
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
Apr 25, 2011 | Refrigerators
Our Sharp refrigerator model SJ-F60PC. 4 doors, freezer at the bottom and fridge at top. The fridge section is not cold although the freezer section is working fine. Much appreciated if anyone can help!
Your defroster timer switch may be at faught. The defrost timer turns on a heating coil to defrost your frige. This is only a guess since I don't have the year. Do this: feel the walls if they are hard and they have no give to them, then your fridge is frozen up solid and no air can circulate. Unplug you fridge for 24 to 36 hours. Put towels on the floor to catch the water. If the defrost timer is bad it will defrost naturally with room temp. Plug back in after 24 to 36 hrs and see if bottom is now getting cold. If it is the defrost timer, the solution is not cheap. It's up to you to repair or invest in new. Good luck Google burdfrenzy
Nov 26, 2010 | Refrigerators
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
General Elec. refrig. about 12 yrs. old. water in bottom of frig., cleaned up, found water a second time.
drain is cloged. at some point the ref section was set too cold. the defrost water from freezer drains through the ref back wall. becaust it was set too cold the drain froze. two ways to fix .... empty unit and unplug for 24 hrs. OR remove back panel, defrost drainrail, remove bottom panel ,remove ice, insert 1/4 inch tube down drain, and squirt very hot water down drain till it is clear of ice..... when defrosted set ref on "3"
Aug 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer not blowing air - bad smell in fridge
Your automatic defroster coil is open and needs to be replaced along with the fan in the freezer that blows the cold air around and also blows air into refrigerator.
Bad smell down below is food rotting in that section because it is not cold enough.
Mar 22, 2017 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
230 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
