Pantone ColorVision Spyder2 monitor calibrator (GEU110) for PC, Mac Logo
Posted on Jan 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have pantone colorplus for windows 98-2000-xp-usb.how do i get it to work on windows 7 from eric aldum
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 18, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1679
Points
The file you need is Spyder2express_2.3.6_Setup.exe
I have installed it on bot a desktop & laptop running Windows 7 64bit. You will still need your Colorplus serial number. I tried other versions from the Colorvision website. Visit http://spyder.datacolor.com/support.php and click the download link.
karan malhotra
Level 2:
Guru:
  • Expert 211 Answers
  • Posted on Jan 10, 2010
karan malhotra
Expert
Level 2:
Guru:
Answers
211
Questions
0
Helped
74446
Points
521
Right click on the application icon and go to complbility tab and select run in windows xp mode.
I don't know if it is a problem but when i plug in a mouse to my computer it doesn't detect it at all i don't know if something changed in the BIOS it has windows 98,2000 i had windows xp on it but it...
Dear macrocks22 :
If you are using a PS2 connection for your keyboard and mouse you will need to reboot windows for it to see them. Its just random how it sees them or not.
Any version of windows earlier than windows XP with second edition update will have problems with anything related to USB. Its just hit and a miss if you are trying to use USB connections with windows earlier than XP with SP2.
Hope it helps, if it does don't forget to give the thumbs up.
tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 • Computers & Internet
How do i get it to work on windows 7
Run it in compatibility mode. If that fails you will have to run it in XP mode. Get that from here
  • http://www.microsoft.com/windows/virtual-pc/download.aspx
5helpful
2answers
How do i install my 2wire 802 11g usb wireless adapter without the installation cd
The Link im giving is for WIn 98,2000,XP etc and Vista.
Both Version of 2wire 802.11g USB Wireless Adapter Drivers are Here:http://www.youtube.com/watch?v=pgGovtiQp3g
Video Explains,Links you and comes with Installation Pdf manual.
Take care
What processor can i upgrade on acer travelmate 220 to
you fogot to tell me the Pentium your processor is using so that i can enrich u with the best
But check the below pentium:
Pentium 1--window 98,2000 and so
Pentium 2--same
Pentium 3-- Window 2000,window xp
Pentium 4-- window Xp , Vista and so on
To my own best use that format.
BYe
Rate this solution.
If u need my assistance then repost your question.
Help with veo stingray
Your cam is not compatable.you will have to purchase a new one for vista.RICHARDM69
Web cam
webcam driver is not matching with your operating system
>please try another driver of webcam which is compatible with your operating system
Top Pantone Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Pantone Computer and Internet Expert? Answer questions, earn points and help others
