Washer is on push pause button and it will not let you open the door. Washer is off and door will not open.
If you are experiencing a door jam the following link explains how to access the manual release:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
If you continue to have problems, please post back and let me know. I hope this helps you.
Turn program selector to "off". Turn
selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start /
pause light flashes.
OR
First, unplug the machine
and turn off the water supply. On the lower right of the front panel is a
6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a
piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip
hanging down on the right; Pull down on this strip while pushing in on the
door, the door lock will release.
Pl click if helped.
