Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
It will not power on.
I banged the door on it while it was in it's bag. It looks fine. LCD and lens are okay, but it will not turn back on.
  • Anonymous Apr 29, 2008
    I have a IXU 60 Digital Camera. One day it was working well, the next, for no apparent reason would not turn on. I charged the battery, nothing. I checked all the battery and door connections and fastenings. I took out the SD card and replaced it. Nothing. I tried to swithch it on while it was connected to my PC, and still nothing. I don't want to buy a new battery if it is a problem with the camera. Any suggestions?
    Margaret
  • Canon Master
  • 4,738 Answers
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on Feb 08, 2008
Camera took a slight bang, while in protective bag, etc. No visible damage - nothing cracked or broken off - but camera wont turn on? Have tried new batteries, external power source etc, it was a gift, and...
either your camera got damaged INSIDE. when you dropped it, small and fine mechanics inside the device might have been damaged. Ask the person who gave that to you what store he/she bought it, then take it there, and get it a look. The technician could help you!
Jun 21, 2009 | Fuji FinePix V10 Digital Camera
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
Bag light stays on, powers on then shuts off immediately. What is the problem?
first check to make sure there is a bag in the machine, if so make sure that its in securely, there is a pin switch in the bag door that wont allow the machine to turn on if there is no bag in it. If that's okay, then find the knob on the top of the machine ( in the middle of the canister ) and make sure its turned to the maximum, that is a sensitivity knob that can keep the machine from working ( in case it was clogged, but if its too sensitive it could think the machine is clogged when it really isn't ).
Sep 16, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Canon PowerShot SD600 Digital Cameral Lens Problem
Adeliak,
This service is free, with advice provided from hobbyists and knowitalls (like me hehehe). Were you asked by someone for a fee? Recommend reporting them to Fixya.
As for your specific problem, lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about half of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 24, 2008 | Canon PowerShot SD600 Digital Camera
Camera turns on for a few seconds, then off.
A light rap with a knuckle when powering up fixed the problem, at least temporarily. Lens extended, camera works fine. Not exactly a technical fix, but it worked for me.
Feb 18, 2008 | Polaroid T737 Digital Camera
Hoover windtunnel will NOT turn on
You have to remove the motor cover, There I believe 5 screw, take off the light lens and remove the screw holding the light. It should then pull off. You say you have power to the Vac, but do you have power to the motor. There also is a thermo by the motor, sometimes they open up, then the motor won't run.
Dec 27, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Sony Cybershot dsc w55 Access Problem
I was ready to throw the Damm thing.. tried pulling on the lens.. no good.. but banged the bottom of the camera on the table and it worked!!!! Started out softly and increased the banging and it real really worked.. Sony needs to get their act together... this is serious business..
Oct 20, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Samsung camera power-on problem and beeping
same problem! camera HAD been dropped....carefully pull up with a gentle twist on the 'tilted ' side.
thanks for the tip! camera works fine!!
Oct 05, 2007 | Samsung Digimax S630 Digital Camera
Indication E:62:10
I had the same error- I tried wacking it against my leg- and now it works again!!! thank you!
Sep 28, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Lens opens and then gets stuck
I just had this same problem. The lens came out all the way, but then make a crazy beeping and clunking sound. The LCD would not come on. I took off the casing, and the clunking sound was coming from the mechanism that has gears in it, and seems to be what makes the lens come out. I tried blowing canned air into it, and banged it around, but nothing worked. Then I pulled a little too hard on the lens and accidently pulled the whole lens off. Oops. Looks like a new camera for me. So my solution is: don't pull on the lens.
Sep 19, 2007 | Casio Exilim EX-S500 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
