Question about Mustek A3 USB Flatbed Scanner
Mustek a3 usb 1200 pro scanner problem
Mustek A3 USB 1200 Pro flatbed scanner problem. Loaded drivers from disc, rebooted, attached scanner and it says scanner busy or not connected. Scanner appears in control panel under scanners and cameras. Scan software comes up but not a peep from the scanner. Says it's not connected. Using Windows XP service pack 2. Just purchased this week. Please help.
  • Anonymous Feb 14, 2008
    I have the same problem. It actually worked for a year just fine and then all of a sudden it will not identify the scanner. Windows sites are no help either.
  • lbellarch Mar 21, 2008
    My mustek scanner had worked perfectly for a couple of years with Windows XP and service pack and then all of a sudden it says it is not connected. I have tried several times to download the new drivers at the Mustek site and followed their directions to the T but no scanning. I am beginning to think it was a Window update that came automatically that is no longer compatible?
    I have tried different USB cord that work with my printer and nothing.
I bought one a couple of years ago. After plenty of hit-miss after trying to get it to work on my fresh XP installations, I have a solution. Installing it the normal way simply doesn't work.
First, go to 'start', 'control panel' then 'system'. Click the 'hardware tab' then press 'device manager'. You'll see a list of hardware.
If your scanner is already plugged in, find it (it could be listed under 'imaging' or under 'other devices'. You should see a yellow exclamation point indicating it's there but not working.
If you go to 'control panel... system' first, and then plug in your scanner, it will pop up automatically.
Now, right click on it, select 'update driver'. A window pops up. Insert the CD, then select 'have disk' and install normally.
Installing the remaining software is optional (acrobat 4.05 and so on)
I've used the "Panel" to scan my pics. Working like a charm.
Posted on Mar 02, 2008
    Problem Solver:
  • 21 Answers
I can tell you of a similar problem/situation with an HP scanner,.
Having tried every method/procedure/trick...nothing worked! Since I've been doing this type of troubleshooting for the past 10+ years, I knew the scanner was operational...but, NOT getting the right commands to work!. With reading & re-reading
HP's site I reviewed some of their FAQ's and forums. Then I found information (still on HP site) regarding issues- unresolved problems-workarounds. I also found that the software (drivers) cd ,DRIVERS! are "incompatable" with Windows Imaging software which is loaded automatically with windows! You have to delete the windows drivers AND imaging program and edit your registry
then reload HP's drivers(pain in the #%$) wasn't worth all the
trouble. Picked up a $9.00 Epson scanner @ Goodwill that is
so easy-fast-sharp,... drivers load without problems. Donated the
Scan RAT and deducted for taxes! Chances are GOOD that the
Mustek software is doing the same. Delete the Mustek software
and see if Windows doesn't recognise and load it's own drivers!
Posted on May 08, 2008
I just installed one of these scanners for a client. The supplied Panel software reports the scanner ready even when not powered up so doesn't inspire confidence. I got it working by running a utility from the Start, Programs entry that announces it's presence on the local network. Can't remember the exact name and I am no longer on client's site, but subsequently could see 2 Twain drivers in Photoshop Elements (Import...) - one directly connected the other the networked version. I chose the networked version even though on the directly connected computer and scanned fine. Then found I could see the hardware as a device under My Computer within Windows Explorer. Right-clcik on it and you can set some property for the preferred software to use this device. After this all you need is connect and power up the scanner, double click on the device in WE and that loads your acquisition software with the TWAIN dialog for preview etc. Maybe the approach from the hardware side is the way to go. Good luck.
Posted on Feb 18, 2008
I cant get my new macbook pro to recognize my mustek Scan Express A3 USB 1200 pro, and i haven't been able to find a driver to fix it so far.
Here is the page to download the drivers you need for the Mustek ScanExpress A3 USB 1200 Pro Scanner:
http://www.mustek.com/mustek/supportdrivers.php
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Mustek ScanExpress A3 USB 1200 Pro Scanner
No drivers windows 7 for scanner MUSTEK ScanExpress A3 USB
you can download driver on this page
http://www.mustek.com/mustek/supportdrivers.php?&show=drivers&disp_cat=Scanner&disp_sr=USB%20Port&disp_mod=ScanExpress%20A3%20USB%202400%20Pro&disp_catid=18&disp_srid=31&disp_modid=230
If this helps orsolves the issue, please rate it and give a testimonial for myresponse
Feb 23, 2011 | Mustek ScanExpress A3 USB 1200 Pro Scanner
Drivers
All the drivers can be downloaded at http://www.mustek.de/a3-usb-600-pro-307/
Dec 13, 2010 | Mustek A3 USB Flatbed Scanner
I need a driver software for my Mustek flatbed scanner with model no: SE A3 USB 600 PRO.
http://mustek.com/mustek/supportdrivers.php?&show=drivers&disp_cat=Scanner&disp_sr=USB%20Port&disp_mod=600%20USB&disp_catid=18&disp_srid=31&disp_modid=120
Jul 31, 2010 | Mustek A3 USB Flatbed Scanner
I need driver for Mustek SE A3 USB 1200 Pro for window server 2003
This is the support page for the 1200 A3 Pro for driver downloads which lists Windows 3.x. http://tiny.cc/Y4rnX
If none of these drivers work for you, you may need to click on: 'Contact Support' at the top of the page to contact Mustek.
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | Mustek A3 USB Flatbed Scanner
User Guide for Mustek A3 USB 1200Pro Scanner for an Applemac ?
So, click on this link:
Fill in the fields, Scanner / USB / Model # and you will have access to the newest drivers and the manuals and everything...
Oct 24, 2008 | Mustek A3 USB Flatbed Scanner
Mustek 1200 UB Flat bed scanner
SELAM BENDE MUSTEK 1200 UB VAR XP NASIL çALIŞTIRA BİLİRİM XP DOSYAYI YüKLEDİM AMA çALIŞMIYOR 98 çALIŞIYOR YARDİMCI OLURSANIZ SEVİNİRİM TŞKLER danyal472004@hotmail.com teşekkürler
Feb 07, 2008 | Mustek A3 USB Flatbed Scanner
Mustek A3 USB Flatbed Scanner Logo
1,993 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Mike
Computer Links
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
