Question about Frigidaire 24 in. GLD2150RCC Built-in Dishwasher
"Clean light" keeps blinking; dishwasher won't start new cycle
The green "clean" light just keeps blinking. If I push all the right buttons to start a new cycle, the dishwasher won't start a new cycle. Instead the clean light just keeps blinking? Any ideas? The green lights just keeps blinking. If I push all the right buttons to start a new cycle, the dishwasher won't start a new cycle. Instead the all the button lights just keeps blinking? Any ideas
  • 2 more comments
  • robert samples May 11, 2010
    have you tried opening the door
  • MAKYS
    MAKYS Nov 03, 2013
    YES, I CHECKED THE SPRAY ARMS TOP IS GOOD BUT BOTTOM SEEMS A BIT WOBBALLY WHEN I SPIN IT.
  • Anonymous Mar 15, 2014
    ge diswasher not starting, this is a brand new D/W just installed this morning by my landlord who is a Plumber. When I press the Start button (fron of D/W) it changes the cycle and doesnt start the D/W.
  • Anonymous Mar 24, 2014
    with door closed blinks cl will not finish cycle
    New Friend:
Thank you Daniel Scott. The solution you posted worked for me and saved me calling a technician. My clean light was flashing and I followed your solution to press Heat Dry - Normal twice. And it worked! Thanks so much!
Posted on Jan 02, 2014
I had the same issue. I tried a lot of different things, including making sure that the arms weren't obstructed, etc.
Then, I switched the breaker off for a few seconds and turned it back on... and it worked ?!?!? I don't know why it happened, but I'm sure glad that fixed it.
Posted on Nov 14, 2008
  • MAKYS
    MAKYS Nov 03, 2013
    THANKS, I WILL TRY THAT!
Check to see how it's loaded. If something is obstructing either of the spray arms it will not start. I had this same problem and checked to see if there was something impeding the arms - I found there was. Reloaded the unit and it's running like a champ now!
Posted on Feb 09, 2008
4 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: Green clean dishes light blinking
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Posted on Aug 04, 2011
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
Sears charged me $200 upfront the technician came and did the exact same combination of keys in sol # 3 and worked and it didnt take even a minute. I called Kenmore and Sears for help before setting up the appointment. They never offered this solution through phone. They said we have to come and take a llok. absolute rip off !!
Posted on May 10, 2008
It says in the manual to check the heating element.
Posted on Sep 10, 2008
Our Whirlpool dishwasher GU2500XTPT1 clean light blinks and will not go off. When we push the start/cancel button, it cycles through the 2 min cycle as the book says it should do and all lights go off. ...
That could be a problem with the control board, but before anything else try unplugging it from the wall, or turning the circuit breaker off. After turning it back on, see if it still happens. Also check to be sure the door is closing properly.
Oct 06, 2017 | Whirlpool 24" Bisque BuiltIn Dishwasher...
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
Dishwasher won't start and the green 'clean light' is blinking
your computer has detected a problem , most likely with the water heating. its locked up. Try pushing the high tem wash buton and then the energy saver button , push them back and fourth a few times(some modles its 2 other buttons) This should actavate a service check cycle where all the lights go on. Let it do its thing, and cancle after a few mins. if it locks up again you need service.
Dec 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
My kenmore dishwasher had green clean blinking light
push cancel or start resume the green clean light will blink after every wash cycle to tell you the dishes are clean on some you just open the door to clear it on some you push stop or cancel
Feb 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kenmore dishwasher wont start blinking clean light
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Jan 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
Feb 19, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Frigidaire 24 in. GLD2150RCC Built-in Dishwasher Logo
2,089 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
