Kenmore Series 90 - Model 20990902
I'm a single pregnant mum to be, whose laundry is piling up.
My Kenmore Washer has stopped spinning when in cycle, the water will pump out but the agitator wont spin. I have removed the cap to gain access to the Agitator however there is no bolt to unscrew or further cap to dismantle. Any ideas how I can get any further to see what the problem may be?
Thanks
  • 4 more comments
  • ownafc Feb 07, 2008
    This is all the information from the plate inside the washer
    Kenmore Series 90
    10 120 60
    Model: 110.20902990
    CK 1766183
    Type II
    there is a bolt but it doesnt have a head on it which would enable me to use a socket set :-(
    I will check your other points. Thank you
    I really cant see any bolt head, please review these photos
    Item 22 blocks the removal of the vertical metal shaft which does not have a head!
    I have removed this piece, now and nothing seems to be broken or any teeth removed or any corrosion.
    I have checked the pump and removed the coupler to the pump, totally clear water drained out and nothing looks like it is obstructing the pump
    The motor does not have black dust or loose parts.
    Previously when the machine was not in pieces, the water did pump out but the machine did not go into spin cycle, it just whirred.
    Where would a belt be? We have 3 dogs, what could dog hair do to a machine? (or is that a dumb question)
    THANKS for ALL your help!
    I don't have an OHM Meter handy to test the switch, I will have to go out and purchase one.
  • 283 Answers
I don't see that model # listed. Please recheck and get back to us
Posted on Feb 07, 2008
  • 4 more comments
  • GORDON'S APPLIANCE SERVICE
    According to my documents once you remove the cap you should see a bolt down at the bottom inside. 7/16" I think. Remove that and the agitator should pull off.Grab from the bottom tho or it could separate. That may not be your problem tho. Check the lid switch. A distinctive "click" should be heard when you lower the lid within an inch or so to the bottom. Also check the coupler. Lean the machine back and check between the motor and transmission for black dust, any broken plastic parts or a looseness in the little plastic joint that connects the motor to the transmission. Let me know what you find
    It should have a head. might be covered wih scum
    Here's what my diagram shows. Look at key #5
    Must be that that part is threaded onto the shaft and you have to turn it off. Get a square object into the recess and try unscrewing it. I suspect the hub will loosen along with the base of the agitator
    These machines have no belt. The coupler
    takes its place. Make sure it isn't cracked especially where the shaft goes through. Doghair is unlikely to cause a problem unless a huge amount of it was interfering with free movement of the inner basket. A sock or other small article of clothing caught in there is far more likely. That's easy to check for shine a bright light into the outer tub and look all around. BTW Did you check the lid switch as I instructed?
    No real need to. Just open and close the lid. A distinctive "click" should be heard. If not replace the switch
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series slow spin
You need a repairperson. It is probably a belt or a switch problem.
Jul 29, 2008 | Kenmore 22422 Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Kenmore 90 Series Washer has slow spin cycle
Washing machine won't spin, seems locked up, when i turn the spin cycle on you can hear the machine trying to spin but it won't budge....... any suggestions???
Dec 19, 2007 | Washing Machines
Washing Machines Logo
515 people viewed this question
Top Washing Machines Experts
