Watts Onan Portable Generator - 5000 , Model# 6500 Logo
Posted on Jan 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 6500 lp onan marquis generator in my rv. It starts then stops after 15 seconds or so. I did a code check on it using the manual and it read code 47. Controller not reading generator running. Any suggestions? This is a 2007 model.
Anonymous
Level 2:
New Friend:
  • Expert 160 Answers
  • Posted on Jan 10, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
160
Questions
0
Helped
65044
Points
350
ONANS ARE PRETTY QUIRKY AS IT IS NOT CONSUMER FRIENDLY. THE GENSET IS DESIGNED FOR ROUTINE AND SIMPLE MAINTENANCE PERFORMED BY THE OWNER, AFTER THAT, U WILL NEED TO TAKE IT TO THE NEAREST DEALER OR CUMMINS DIESEL REPAIR SHOP.
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Jan 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
12705
Points
36
Does it the motor stall or does it just quit producing power?
Im a cummins service mechanic feel free to email me at [email protected]
  • Anonymous May 08, 2013
    My Onan Marquis 6500 LP generator works fine in Iowa (close to sea level), but when I travel to Denver (high altitude) it runs for a few minutes then stops. I can't seem to find a way to adjust for high altitude. Any help would be appreciated.
I have a 2006 winnabago with onan marquis gold 6500 lp generator that won't start
Check the Onan web site for troubleshooting. Otherwise it's probably time to go to an RV center to have them check it out.http://www.cumminsonanstore.com/
I have a 6500 lp onan marquis generator in my rv that wont start. any suggestions?
Check the fuel. If old, drain & refill it.
Check for spark.
If the fuel is there and good, trace it to the carburetor. Check the carburetor bowl for fuel.
Check the spark plug, the magneto, any switch that breaks the circuit or kills the circuit for spark.
If you're getting good fuel to the carburetor and you're getting good spark, try to start it with ether spray.
You might also want to check compression while you're checking everything else.
Onan genarator will not crank
If it wont crank, check to see if the solenoid on the starter pulls in, the starter and solenoid are one unit, it sounds like an internal starter contact, if you have 12V going to it. Assuming the battery is good. When you press and hold the stop button does the fuel pump pump prime? if so control board has power
Electric control circuit for onan 6.5 hgjab-1272
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
2answers
Onan 7000 watt generator rv starter problems
Can you be more specific than just starter problems?
Onan 5500 RV generator starting issue
Sound like a dead battery, or poor battery volatge getting to the unit. The clicking is fuel pump and or solenoid trying to pull in.
2answers
I need a manual for onan 6500 lp genset
You can buy a service and or operator manual from advanced-power-technologies.com
I have a Onan 7000 genset in my rv It starts and
Either you have a kill wire ( if I remember it is the brown wire) that is disconnected on one end or the other Or your in coach switch is bad.
Check the switch this way
Remove the switch from the dash/ mounting surface unplug the brown wire - start the genset - ground the brown wire - it should kill the motor
If it kills the motor your switch is bad
Need onan marquis 5000 model 5bgmfa26105f wiring
Give me to full model and spec # and I will email you a service manual.
Top Watts Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
