Question about Audiofonics ADF-243 Car Audio Amplifier
Schematics i have an audiofonics adf-243 and i was wondering where can i find the schematics for it you can contact me at renaldo30@aim.com
  • Anonymous Apr 28, 2008
    I need the channel number of audio fonics adf-243 or the diagrams of this equipment
I have two pyramid saund car. Bat i dont have a schematics for this products: pb610gx and pb810gx.
Pls help me
Orsely Azevedo, from Brazil
Posted on Jul 31, 2008
  • 86 Answers
Hello try this www.eserviceinfo.com...takes a bit to work out how to get them...when you do you have to download bitzipper (these are rar files )..then adobe8 .bitzipper can convert to pdf files so you can read them ...hope you have some luck
Posted on Feb 12, 2008
Audiofonics ADF-240 Car Audio Amp
Hi There buddy.
I have on many occasions had problems with the actual LP/HP/Full Range selector switched on the amplifiers.
Remember that the input signal runs through the switches before it gets to the main amplifiers.
Check that out and let me know.
Oct 30, 2009 | Audiofonics ADF-240 Car Audio Amplifier
Building a ported box for three audiofonic 12" subs but need spec
you need to find out factory reccomendations for airspace and port size. Many people with lots of experience building boxes still fail to do this and build good quality boxes, but for the wrong speakers.
Oct 03, 2009 | Audiofonics ADF-272 Car Speaker
Audiofonics adf-241 no power all wires connected fuses ok.
Hello pimprascalz,
Many amps will go into protect mode if one of the speaker wires is shorted or grounded, or if the voice coil(s) are defective. Try disconnecting the speaker wires one at a time and see if the amp still goes into protect upon power up. Likewise, some amps will go into protect if one of the inputs is grounding out. Again, to troubleshoot, disconnect them one at a time and try the amp. Next, make sure that the amp itself is not grounding. Most amps need to be mounted to a nonconductive surface. If the case contacts the frame of the vehicle, it can cause a problem. If the problem is not in the speaker wires or the input cables, the amp case is not contacting the vehicle frame, and you have checked your power, ground and turn-on leads, then the amp itself is probably faulty.
Hope this helps.
May 19, 2009 | Audiofonics ADF-241 Car Audio Amplifier
BLOWN FUSES
If the fuse only blows when the amp is driven hard, the impedance of the other speakers is likely too low.
Sep 21, 2008 | Audiofonics ADF-243 Car Audio Amplifier
Help
From what did the wire become disconnected (amp, battery, cap...)?
Jun 18, 2008 | Audiofonics ADF-241 Car Audio Amplifier
Audiofonics
i would go with the 801.And ithink u meant the 4501 not 4051.Both super power amps. competition stuff.your woofers are 4ohms dual voice coils.so you can series the coil on eaach woffer and use the two channels on the amp.they play at 2ohms.I think if you drop it down to 1 ohm you really be taxing you alternator that is series power.Yioou would need a special alternator.Even with them running in 2 ohms you better hav eat least a 2 farad cap.OR two batteries.. ! more thing don 't pump it up with window s closeed .you'll pop them.serious dbl. you be pumping.I'm jealous.Rating please and enjoy.
Feb 09, 2008 | Audiofonics ADF-272 Car Speaker
ADF-243 Amp
What you need to do, is also run the rca cable from the back of the deck to the amp. The speakers are already powered by the deck. You can then hook up your subwoofers. The switches are for your own taste.. you adjust them as you go.
Jan 30, 2008 | Audiofonics ADF-243 Car Audio Amplifier
Cubic inches of a Audiofonics 12
You should be able to download the owners manual for these speakers. The manufacturer will give detailed specs. on the type and dimensions of recommended enclosures for this particular speaker. If nothing is available to download, you could try to contact the manufacturer directly.
Jan 03, 2008 | Audiofonics ADF-272 Car Speaker
Amp fan not working
If you have any experiance with electronics remove the casing and check the fan with a external 12V power source. If the fan still does not work, it needs to be replaced, try and get a brushless fan as it will last alot longer.
Mar 10, 2007 | Audiofonics ADF-242 Car Audio Amplifier
Audiofonics ADF-243 Car Audio Amplifier Logo
316 people viewed this question
Top Audiofonics Car Audio & Video Experts
Mark Skinner
Billy McCain
Billy McCain
Level 1 Expert
Bill Boyd
Are you an Audiofonics Car Audio and Video Expert? Answer questions, earn points and help others
