Question about ASUS P4GE-MX Motherboard
How to connect
Hai i buy SATA harddisk i dont know how to connect please help me;;
  • Anonymous Dec 21, 2008
    I dont have S-ATA port on my mother board, how do I connect S-ATA Data Cable.
    Scholar:
  • 119 Answers
However I would like to add to my firnds here comment that if you are not sure of which is the sata connector,try to look into the user manual for further explanation or if you dont have it please download it from the manufacturers site..
give us an answer  or tell us if you stilll have problems..ok?bye bye
Posted on Feb 07, 2008
    Problem Solver:
  • 8 Answers
For this u must have a sata port on ur motherboard. u should have a sata cable just connect these to ur hdd and then to sata port detect it restart ur system and it will work
I have a Soltek SL-K8AV2-R1L with one 160 gb sata harddisk (with XP on it), a 40 gb IDE harddisk on IDE channel 0, and two DVD/CD-drives on IDE channel 1. Tried to reinstall XP but XP setup did not...
Welcome to Fixya. The first thing you need to check is if the SATA Hard Disk is detected in Bios. In the system information you will see there the list of the drives including the DVD and the IDE hard drive. You can also check the Boot Sequence or Priority if it is there. Please let me know if you find the SATA hard disk on the list.
Thanks
Apr 15, 2011 | Soltek SL-K8AV2-R1L Motherboard
Hi,I've an external case (diamondmax 11 Model:6H500F0)--500GB SATA 3.0GB HDD. And I wanna to activate it,but I Dont have the Installation CD,plz I need your help URGENTLY. (I've an widows XP for my...
Maxtor DiamondMax 11 is a SATA Hardisk and you need SATA External Case. After adding the Harddisk, all you have to do is connect it to the system via the cable of the external case. There is no need for additional drivers/ CD as all the external harddisks are 'plug and play'and the Operating System detects them automatically.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Maxtor DiamondMax 11 400GB 7200rpm 133MBps...
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Mother board cant detect my Sata HDD, please advise me urgenly...
I will advice you to exchange the HDD with someone or with brand new one as it seems to be problem with drivers of the sata.
Sep 20, 2009 | MSI RC410M-L Motherboard
Compaq deskpro 2000 error code 1780 disk 0 failure,how do I fix it?
first open cpu cover and reconnect both connection to hardisk. Like sata or ide and power cable.
Then check in bios .
When you power up the computer pressF2 or "del" or F5 to enter in bios setup then load optimal defaults.check your harddisk is proeprly detected in bios.
also if youi have sata harddisk then enable sata option in advanced .
then save settings and exit.
Thanks for using fixya.
Please rate solution if it helps.
Jul 23, 2009 | Computers & Internet
HP d530 PC - SATA Harddisk - Chassis does not close any more
Martin,
They make SATA cables with a 90 degree connection on one end.
Hopefully this will solve your clearance problems with your case.
Here is a link to website that carries these.
Website Link
They work great and fit tight against the drive.
Hope this helps,
Eric
Jan 18, 2009 | HP Compaq d530 PC Desktop
BIOS cannot detect SATA harddisk
Most motherboards have multiple plug-ins for Sata drives. Try another plug in. This will typically solve this type of issue.
Dec 30, 2008 | ASUS P5LD2-VM Motherboard
SATA HDD make SLAVE
IDE Cable with 3 connectors (you have 1 or need to buy 1) :
- blue: conn to motherboard
- black: conn to master HD
- grey: conn to slave HD
Cable (select:) cable will auto detect with most modern HD's from same type (SATA it was i think) and you need to go to you're BIOS, set up cable select for the HD's. Maybe best to set up master first, not both at same time. If you have a SATA and ATA set up the master first, then other. So if SATA is slafe but it in grey connector, otherwise black. For an ATA you might need a converter cable for the power, most motherboards don't have 1.
Oct 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Help regarding laptop harddisk
the motherboard for that unit MAY NOT have SATA capability. check for that at the acer site.
Mar 08, 2008 | Acomdata HybridDrive E5 Hard Drive
ASUS P4GE-MX Motherboard Logo
48 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
