Reciever my receiver is getting power but the power button does not turn it on and off so it is useless
  • 2,130 Answers
Did you try unplugging the unit and taking the cover off and seeing if the internal fuse is blown? There maybe a fuseholder on the rear of the receiver too. It is usually black, 1/2" in diameter, with a twist off cap and the marking of the fuse rating in white. If not, you'll have to take the cover off and look for a blown internal fuse. If the fuse isn't blown, you could have a faulty on/off switch or power supply. If you replace the fuse and it blows again, then something has failed and is drawing too much current and causing the fuse to blow. It could be a bad power supply or a shorted audio output module. If that is the case, it will need to be taken to a shop to be serviced.
Let me know if I can be of further assistance to you.
- Jim
Posted on Feb 07, 2008
How to reset a yamaha 5440 reciever back to factory settings
Hold 'fm/am' and 'input mode' and press power button. Then cycle through menus using 'program' button until you come to the selection that says "preset inhibit". Then press 'preset/tuning' button to change it to "preset reservd". Then press power button to turn it off. When you turn it back on, it should be back to factory settings.
Dec 30, 2012 | Yamaha HTR-5440 Receiver
When i power up the reciever and watch tv the reciever turns off and the power button blinks red. I unpluged the reciever for 1 hour and put it back on. nothing changed. i even unpluged the speaker wires...
You have an internal short in your receiver could be power supply or most likely a output transister. There is a code to the blinking red light check your manual it may list the number of blinks with problem. However its not a simple fix. plus make sure HDMI cable is unplugged when reseting receiver if this cable has a short it may cause it to. Sorry to hear the bad news, nice receiver
GOOD LUCK....
May 24, 2010 | Denon AVR-1508 Receiver
Sennheiser em100 g2 receiver passes major static to mixer
This is a well known problem with the EW100 series that is easily solved.
You will need to run this reciever into a line input via a mono(TS) jack to jack lead. this will bypass the phantom power.
Make sure that you set the AV OUT to +18 in the reciever menu to get optimum level.
Phantom power is only present in the microphone inputs XLR3.
Hope this helps.
Rus.
Mar 01, 2009 | Sennheiser EM100G2 RACK MOUNT G2 RECEIVER...
Reciever turns itself off
try cleaning it out, get all the dust out of it if not , you may have some screwed up capacitors or transformer
Jan 02, 2009 | Yamaha RX-V757 Receiver
My denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Jun 23, 2008 | Denon AVR-2805 Receiver
Standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Jun 14, 2008 | Pioneer VSX-D308 Receiver
STR-DE545 Receiver -
I just turned my DVD player off when my STR-DE545 was still in DVD input mode and it came up LOCKED, maybe the input that you are using is not receiving a signal?
Feb 03, 2008 | Sony STR-DE545 Receiver
Power on
throw it in the trash and get a sony brand reciever.
Nov 04, 2007 | Onkyo TX-DS676 Receiver
Shows to be stuck in Standby.
hold down the enter button and the advanced surround button for 5 seconds or so and the amp will restart, the display will come up and hopefully it will be ok. its often caused by using speakers under 8 ohms, or damaged speaker cables etc
Mar 20, 2007 | Pioneer VSX-D712 Receiver
Programming the directv remote to program a sony audio receiver
Go through the process of setting up the remote again instead of trying the volume first use the power off button. In my experience, Sony receivers can be picky and power cycling "will" insure the code set, then try the volume.
Nov 03, 2006 | Directv HR10-250 DTV Receiver
264 people viewed this question
 Grubhead
Grubhead
