Staefa building controls
The NCRS boards are not communicating- even when we plug in a laptop with MS1800 right into the NCRS- "Failure to connect"
help?
    Sergeant:
    Champion:
  • 326 Answers
Good day,
Ensure power to NCRS board.
Ensure communications protocol on laptop is correct.
Check MS1800 is set for correct NCRS-xxx (different versions of the NCRS).
Ensure cable is RS232 or RS485.
Posted on Feb 08, 2008
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
What does F70 mean on a front load dryer?
Hello Carol;
My name is Peter. I am a retired field service appliance technician.
F70:
No communication between the electronic control board and the user interface control board assemblies.
Unplug the dryer. Check the wire harness connections between the main electronic control board and the user interface control board assemblies. If the connections are sound, have a technician diagnose the cause of the communication failure. The main electronic control board and/or the user interface control assemblies might need to be replaced.
Dec 06, 2014 | Whirlpool Dryers
30.01.34 scanner failure 9050
Scanner initialization failed, and the copy processor
board (CPB) is not communicating
with the scanner-controller board (SCB).
1. Turn the product off, and then on.
2. Check the scanner controller board
LEDs.
3. Check the connections to the scanner
controller board.
4. Replace the scanner controller board.
Jul 30, 2014 | HP Office Equipment & Supplies
Pc Er Error code
Jim, Pc Er is a Communication circuit failure on main board or
Communication circuit failure on control panel board
Could be a loose or corroded connection, a bad mother board or a bad display board. Before doing anything, unplug the refrigerator for 5 min and plug it back in. This may reset the motherboard. If not, check the comm cable at the display and the motherboard. if ok, then you will need to replace either the motherboard or the display board. There is no way of determining which one to replace.
Apr 10, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
I have an F11 code
Washer will suddenly stop with 1 minute left on cycle and shows the F11 error code...at times it may show the FdL code. The washer will then not finish no matter what I do. If I unplug the unit from the outlet that does not guarantee that when I plug it back in it will start up. Fifty percent of the time it still shows the F11 error. It can take hours to finally get the washer to cancel out so I can take the laundry out that has not been spun out.
The F11 error code indicates a serial communication problem between the central control board and the motor control board. This can be caused by:
  • A loose or failed wire harness connection between the central control board and the motor control board.
  • A bad wire harness connection between the motor control board and the drive motor.
  • A failed drive motor.
  • A defective motor control board.
  • A failure in the central control board.
The diagnosis of this failure usually requires a technician. If you are able to unplug the washer and safely access the central control board and motor control board, you can check for a loose wire harness connection.
Jan 24, 2011 | Kenmore Elite 45986 Front Load Washer
Error code F11
F11 is an indication of a communications problem.
Communications cannot be sent correctly between the machine control board and the motor control board.
Here are some possible causes:
  • Loose wire connection at either the machine control board or motor control board.
  • Machine control board failure
  • Motor control board failure
  • Door lock
  • Motor
Error codes can be caused by a Power Surge or other electrical anomaly, attempt to return the washer to operation by following the Hard Reset procedure below.
In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
  1. Unplug or turn the circuit breaker off for 10-20 minutes.
  2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  3. Press the Pause/Cancel/Stop button twice to clear the display.
  4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Aug 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
On my 30cxi boiler its flashing up f12 do you no the problem?
Electronic board and touch module communication error 1. Disconnect power for 1 minute.
2. Reconnect power.
3. If failure remains, replace board connection cable between touch control module and electronic control.
4. If failure remains, replace the electronic control.
5. If failure remains, replace the touch control module
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#ixzz0tXhzQz2F
http://www.appliancepartspros.com hope this helps
Jun 25, 2010 | Kitchen Ranges
F 11 code
  • Door lock
  • Motor
Jun 17, 2010 | Kenmore HE2 Plus Front Load Washer
HE5 frontload washer error f11
F11 error code indicates a communication problem. The communication between the Central control board and the Motor control board cannot be sent correctly.
Potential causes:
1. Loose connections between the motor control board and the machine control board, or at
motor
2. Machine control board failure
3. Motor control board failure
4. Motor failure
5. Door lock failure
If this answers your problem, please rate my answer.
Thanks,
David
May 27, 2009 | Kenmore Elite 45986 Front Load Washer
4 beeps 2373 laptop
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
IBM POST Diagnostic Code Descriptions
Code Description
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Colour/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Colour/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
294 people viewed this question
Alun Cox
David Payne
David Payne
