Question about Dell (E210882) Motherboard
High density memory
I am trying to upgrade a Dimension 1100 with the e210882 motherboard. am about to purchase 2*1gb memory sticks:-
GB PC3200 DDR 400 RAM 400Mhz 2x 1GB 2 GB G DIMM MEMORY
I am aware that my system can only handle 2 gig max.
These sticks are 1 gig each.
Specifications:2GB (1GB x2 KIT) 400MHZ 184PIN DDR Memory, No-ECC. Higher performance over mainstream PC100 or PC133 memory. Up to 3.2 GB/sec of peak bandwidth using PC3200 DIMMs (with DDR400 memory chips). JEDEC Standard. 184 pin DIMM, non-ECC. DIMM Lead pitch: 1.27 mm. 2.5 Volts. SSTL-2 I/O Interface. SPD Support. Support for Memory Chip Stacking.
Apparently this memory is high density. Does anyone know if this memory will work on this motherboard?????
Many thanks for all help.
    Master:
    Sergeant:
  • 440 Answers
Need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Posted on Feb 07, 2008
2 Suggested Answers
Demmy
  • 59 Answers
SOURCE: Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Posted on Feb 05, 2008
I `have a dimension 3000 I ordered 2 1gb pc3200 ddr 128x64 to upgrade my computer but but every time i put 1 or 2 or the sticks in the computer. it beeps 5 times and will not boot up. I will boot if i...
Hello Sir. your PC3200 DDR (PC400) is not compatible with the dimension 3000, get a PC2700 (PC333) instead. or upgrade your motherboard to use a PC3200. BTW 2GB on an XP is too much memory. Use Vista, your processor lags. Its wiser to upgrade your motherboard and processor.
Jan 11, 2011 | Dell Dimension 3000 PC Desktop
I have 2 sticks of 512 MB DDR 400 pc3200 in the motherboard but when i use crucials scanner to find out what memory is compatable with my computer it shows 2 sticks of 256. This board is supposed to be...
hi
your motherboard supports following RAM only
Note: PC2100/PC1600 up to 3 DIMMs; PC3200/PC2700 up to 2 DIMMs; 1GB PC3200/2700 with 32 DDR chips up to 1 DIMM only)
Aug 04, 2010 | ASUS P5S800-VM Motherboard
I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
Slot 1
Slot 2
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845D
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 1.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: Yes.
Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
RAM compatibilty
No, DDR 400 will not work. The best thing you can do is call Dell and give them your information. Model number and that kind of information and let them tell you what kind of ram you need. If you put the wrong type of ram in your machine it could cause major damage. There are so many different kinds of memory out there, not to mention high and low denisity. Your machine may use PC2700 high density and if you try to use PC2700 low density it will not work. One other thing that you can try is uninstall a stick of your ram and write down everything on the stickers and then go to some place like kingston memory and use their memory locator to find what you need.
Dec 01, 2009 | Dell Dimension 2400 PC Desktop
Gateway motherboard E210882 I upgraded the memory from two 256MB to two 512MB. Used DDR PC3200 (400Mhz) Now I keep getting a memeory error
Recommend checking the motherboard specifications to see how much memory and what type it can handle. If you don't have this, you can easily locate it on the internet. The replacement memory sticks will need to be of the same type. That means your motherboard may not be able to handle the PC3200 type chips you have. It may require the PC2600 type instead.
Oct 25, 2009 | Computers & Internet
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
Memory Stick Installation
So it seems you got the DDR / DDR2 side of the equation correct, but unknown to most, there is 'low' and 'high' density memory.
The density of memory refers to the number of chips used to make the total amount of memory that your memory stick contains. e.g. High density memory has few, large capacity chips to make up the 1024MB of memory on the stick, whereas low density memory uses many, small capacity chips to make up the same 1024MB total on the stick.
Typically, if it is a low / high density conflict, it is the 'low density' sticks only that will boot.
Me, I purchase Kingston memory when I'm unsure what the motherboard will be, and it has never failed to work.
I fix computers.
May 19, 2008 | EliteGroup PM800M2 Motherboard
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
Dell (E210882) Motherboard Logo
338 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
