Question about HP DeskJet 5550 InkJet Printer
The cartridges are "stuck" in place - won't move left or right - yellow lights is flashing
What i thought was just a paper misfead seems to have had a bigger impact.  the cartridges are stuck in the "middle" of the printer and they won't move right or left.  the yellow light is blinking and i can't print.  tried turning it on and off.  tried unplugging it.  nothing seems to get the cartridges moving again.  anyone familiar with this sort of problem?
thanks!
Julia
    President:
  • 2,351 Answers
With the power off. Push the carriage to the left about 4". Power up the printer. It should go through its normal reset. When it's done making noise look in & see if it went back to the center?
Open Printer & Faxes. Your default printer should have a check nex to it. make sure it is the 5550. Click the 5550 once so it's highlighted. Click file & open. Clear anything that is waiting to be printed. Close all the opened windows. Re-start the Pc.
I should list HP's suggestions too:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00034342&lc=en&cc=us&dlc=en&product=71896&rule=45014&lang=en
Try a test page even is so. Post back...
Posted on Feb 07, 2008
When i turn the printers power button on a little yellow light comes on and the printers sound goes off.
If a yellow light comes up that means something might be stuck inside of the printer because i have 2 or 3 printers the same a little bit as your's
  1. Unplug the power cord.
  2. Check to see if the print carriage moves freely from one side of the printer to the other. ...
  3. Remove the print cartridges. ...
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawerimages?q=tbn:and9gcql4vvqpurkyfvqqmw9rwhtdflbrbabxkdolb-lu_srxwwin5o-9q
Jan 15, 2016 | Canon PIXMA Office Equipment & Supplies
Canon ip100 portable printer ink cradle stuck on right hand side
I had this same problem. Count the number of blinks in sequence of the error light. it will flash green and yellow, and then just straight yellow for a number of flashes, then it will flash green again and the same number of yellow flashes again. Here is the diagnostic guide.
Two flashes: Printer is out of paper. Paper does not feed
Three flashes: Paper jam
Four Flashes: The Print Head Lock Lever is not locked properly / Ink tank is not installed properly. / Ink may have run out
Five flashes: Print Head is not installed./ Print Head is defective
Eight flashes: Ink absorber is almost full
Nine flashes:No response from connected digital camera or video camcorder/Connected digital camera or video camcorder is not compatible with this printer./PictBridge compliant devices are attached to both Direct Print Port and Bluetooth Unit Connector
Eleven flashes: Automatic Print Head Alignment failed
Twelve Flashes: Low battery level
Fifteen Flashes: Ink tank cannot be recognized
Seventeen Flashes: Ink has run out
Eighteen Flashes: Printer detected ink out condition
Nineteen Flashes: A USB hub is connected
Mine had 10 Flashes and the Print Carriage, was bad. Cost almost as much as another printer so thats what I did. I did take it apart and got it unstuck, but still didn't work.
Mar 10, 2014 | Canon iP100 Portable Printer
Ink cartridges stuck on left side of carriage. Won't move. Tried all of the suggestions and still says carriage jam.
it will be stuck in roller cleaner mode, that is mechanical. the only real way is to push it thether over to the left. with the power off the printer, then close the compartments and turn on the printer it can take 2 o3 goes as it will try to move it right. you have to get it off the clip that is holding it there. the cartridge is held in place to stop it moving while the roller is cleared.
Jul 03, 2017 | HP OfficeJet 7410 All-In-One InkJet...
My C46 has been spoiled by someone who can get into my home. It will not allow the paper to go through It is grabbed on the right and goes to the left. I've tried finding something to change about it. ...
Typically there is a small bit of paper that is stuck somewhere in the paper path. It is now probably black with ink and will be hard to see. Usually running some card stock through the printer will clear it. But if necessary, manually push some thin plastic (maybe from some clothes packages) back and forth through the paper path, especially at the edges to try and dislodge the offending clog.
What you don't see is that when you close the cover the ink cartridge moves back and forth, grabbing the edge of the paper on the right and pushing it to the left. There may also be a piece of paper stuck on the ink cartridge head or carriage. Remove the ink cartridge, inspect the head and place where it moves to see if there isn't a bit of paper stuck there (again, will be saturated with ink). Use same process to remove. Try not to use a knife or other sharp object as it might damage the printer.
Dec 02, 2008 | Epson Computers & Internet
Will not print / cartridges will not move back and forth
I had this happen to me the other night and I had to restart the printer to get the print job out of the que. You could try that.
While it's restarting, unplug the power cord and the usb cable. That should reset it.
Jun 21, 2008 | HP DeskJet 5550 InkJet Printer
PAPER JAM
SUGGESTION #1 The print carriage might be jammed. Follow these steps to correct the problem:
  1. With the power on, lift the print cartridge access door. The print carriage should move to the access area located on the right. If the print carriage stays all the way left, reset the unit by unplugging the then plugging in the power cord. If the carriage still does not move to the right, continue with the steps below.
  2. Disconnect the power cord from the all-in-one.
  3. Remove both print cartridges.
  4. Push the print carriage slightly to the left and then to the right to verify that the print carriage is not jammed. If the print carriage will not move, check for obstructions under and around the carriage.
  5. Close the print cartridge access door.
  6. Plug in the power cord.
  7. When the " Insert Print Cartridges " message displays, open the print cartridge access door and insert the print cartridges. Verify that both cartridges are seated correctly and lock into position.
SEGGUSTION #2 cleaning rollers Over time dust and paper fibers will accumulate on the paper feed rollers. This can cause paper feed problems. Follow the steps below to clean the rollers: Figure 3: Paper feed rollers c00212278.jpg
  1. Turn off the all-in-one and unplug the power cord.
  2. Remove the rear access door (as describe above in this document).
  3. Clean each roller using a clean lint-free cloth lightly moistened with water (distilled water preferred). Rotate the rollers to clean the entire surface.
  4. Verify that the paper feed rollers on the rear access door are clean and rotate easily.
  5. Re-seat the rear access door.
  6. Plug in the power cord and turn on the all-in-one.
If these suggestions don't fix the problem feel free to write back to me. Try to be a little more specific i.e does paper feed properly, error message shows with paper/without paper or both, do any of the lights flash when this happens, have you tried diiferent paper sizes ot types. Have you taken it apart to check for any obstructions?
Jan 06, 2008 | HP PSC 2355 All-In-One InkJet Printer
Paper jam?
Check Paper light flashes but there isn't a paper related problem The check paper light may also flash if there are other problems. Verify the following conditions:
  • Verify that the print cartridge door is closed.
  • The print carriage may be jammed, follow these steps to correct the problem:
    1. Open the print cartridge access door. If the print carriage can move, it should move to center. If the print carriage stays all the way left, unplug the power cord and then plug it back in. This will reset the unit and may allow the print carriage to move from the left.
    4. Move the print carriage left and right slightly to verify that the print carriage will move freely. If the print carriage will not move freely, check for obstructions.
    6. Plug the power cord back in.
    7. After the all-in-one initializes, the print cartridge light will flash. Open the access door and install the print cartridges.
    8. Close the print cartridge access door. If the problem returns, remove the print cartridges and wipe the electrical contacts before reinstalling them.
  • Try to make a copy. If the all-in-one pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism. Contact HP for assistance.
Nov 01, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
221 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
