Question about Biostar P4VMA-M Motherboard
Disabling Onboard Video
I'm having trouble installing an video card in the agp slot on this motherboard. Do I have to disable the onboard video ? If so, how do I do that? I've tried to disable in device manager with no luck. Also I went into bios and told it to recognize the agp slot for video with no luck. The manual doesn't mention any jumpers. PLEASE HELP before I throw it out the window.
Thanks
    Scholar:
  • 119 Answers
No you dont need the jumpers or some from there...just before booting your OS,go into the bios field.
there you will find the option you must set to disable.
the exact point youll find it I cant tell you because bios are different from board to board..depending of the manufacturer..just surf the bios,youll find it and disable it
good luck bye
Posted on Feb 07, 2008
How do i disable onboard video on a intel d865glc motherboard?
A couple things to try:
  1. Most important, check with Intel's support site to see if you have the latest version of the BIOS.
  2. Boot to the BIOS: Choose "Configuration", then "Video", choose "Enable if Primary" or if you're feeling brave choose to Disable it entirely. WARNING: DON'T do this until your other card is working properly! You've been warned!
  3. While still in BIOS: Choose "Configuration", then "Video", choose "AGP" if available, or "Auto" if AGP is not an option.
Information from Intel support website.
Oct 21, 2012 | Gigabyte GV-N76G256D-RH GeForce 7600GS,...
Video not working on 755Twins-hdtv motherboard.
The option to disable the onboard graphics is in the BIOS.
You need a PCI-express card. You should not be trying to fit any graphics cards into the PCI slot.
The VGA/HDTV conection should have been supplied on a seperate card.
Your support page is here http://www.asrock.com/mb/overview.asp?model=775twins-hdtv
Aug 01, 2010 | Asrock Computers & Internet
Wie disabled man die onboard-graphic? Ich möchte eine Radeon X1600 mit 512 MB in den AGP-Slot einsetzen. How disabled the onboard-Graphic? I want use a Radeon X1600 in the AGP-Slot
Just plug in the Radeon video card in the agp slot and the system will automatically detect the new video card and disable the onboard-graphics.
Oct 30, 2009 | Computers & Internet
Comp will not recognize my agp radeon HD2400 pro graphics card
Try the following : Go into the setup routine using the onboard video. Go to the  Intergrated Peripherals.
Find the onboard video and change it to disable. Save changes.
Change monitor to the AGP card.
  I hope this helps.
Here is a web site for your Award Bios setup:
http://www.buildeasypc.com/sw/bios_setup.htm
Inegrated Peripherals
This menu allows you to change the various I/O devices such as IDE controllers, serial ports, parallel port, keyboard etc. You can make changes as necessary. See figure 5.
Dec 19, 2008 | Biostar P4M80-M4 Motherboard
Is visiontek a radeon hd 2400 pro agp 8 compatible w/ p4s800- mx?
ATI has recently written some better drivers for the 2400 Pro AGP cards,... Make sure the setting in the BIOS for the motherboard is set to the AGP or PCI for primary video. For AGP, make sure that you have the power from the power supply connected to the video card. Make sure that your motherboard does support 8X AGP video cards. If you are not sure, please check with motherboard manufacturer for compatibility.
Dec 13, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
System doesn't see AGP card
Hello flaxx
I believe you'll need to find a way to disable your integrated (onboard) video in the BIOS. I know there isn't a direct way to do it but, please, see the next link. The user there found a way.
HERE is the way another user accomplished this task. (disabling onboard video). It concerns a different Asus motherboard but, I checked your motherboard manual, those same features are available.
HERE is the AsusTek forum for your motherboard. You can search and post here. There will be other users of that same board there that I'm sure will be able to help you.
HERE is your motherboard manual. However, I didn't see anything that particularly addressed disabling the onboard video.
Please, post back here w/ your results, questions, and any comments, etc.
Thank you
BJ @:)
Apr 12, 2008 | ASUS P4GE-MX Motherboard
Need help
You need to enter your motherboards bios. As the system starts up press the Delete key every two seconds. Hopefully you'll have video doing this. If you do not have video display. You'll have to remove the new video card for a short while. Again enter your bios. Still have your manual? If not click the link & download it here. http://www.foxconnchannel.com/EN-US/support/downloads.aspx?ProductModel=865G7MC-ES&TypeID=en-gb0000001
Enter Advanced Chipset Features
Goto pg. 33
On-Chip VGA (Default: Enabled). Disable this.
Init Display First (Default: Onboard/AGP) Change to AGP/Onboard. The AGP is to load first before the onboard.
Save & shut down the system. Clean out the AGP slot. There can be a dust build up from not using it. Canned air works well.
Leave the side case off untill your sure the 7600 is running correctly.
Get to know your board alittle. Read the manual a wee bit.
Good Luck! Enjoy!
please vote
Feb 15, 2008 | Foxconn (865G7MC-ES) Motherboard
Gigabyte 7VM400M-Rev.1 Onboard Video
format ur computer once again.. n install the driver..
Feb 14, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
How to disable onboard VGA
I believe if you install an AGP card the onboard VGA is supposed to be automatically disabled. Did you buy an AGP card?
Nov 28, 2007 | Foxconn P4M800P7MA-RS2 Motherboard
Hp compaq dc5000 small form factor
Hi, uninstalling the onboard video will only be reinstalled by Windows next time you boot up. Disabling it in the Device Manager might and mght not do the trick if your mb is set on using the onboard. You might want to try and disable the onboard video in the CMOS/BIOS set-up. In some instances, you are asked in the BIOS what video will be used such as onboard, AGP or PCI or a selection of something like that. Also you can try and not allocating any memory to the onboard video. Hope this be of some help. Pls post again how things turn up. Good luck.
Apr 28, 2007 | HP Compaq dc5000 PC Desktop
Biostar P4VMA-M Motherboard Logo
309 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
