Question about Canon DR-2580C Path-Through Scanner
Canon Unknown Error
This is an error when scanning a batch to file after it scans pg 1. I have loaded Capture Perfect from the Installation CD and have downloaded all available upgrades possible from the canon website with no change. I have uninstalled all software and reinstalled since, but still get the error: unknown error canon dr2580c driver version 1 2 10509 29001 4523
This scanner works fine on other pc's or laptops in our group but this just refuses to work.
Thanks for any help or suggestions.
KA
Please run Scandisk on your computer. If the problem persists even after this, reinstall OS. You need to reinstall other applications also.
S. Mohan
Posted on Mar 09, 2008
Received this error while scanning: User cancelled operation Canon DR-9050C Driver Version 1.9.11303.26001 (-4526) File access error occured. Check write protect or disk full
Maybe the default folder that is set up to receive scanned images has been set as 'read only'.
This sub-folder will most likely be in your default user folder.
Look for something similar to 'Scans' 'Scanned' 'Scanned images'.
Right click folder name in Explorer to view / change properties. OR..
Your printer interface software should allow an option to change the save path.
Also check drive capacity in My Computer screen.
Nov 20, 2017 | Canon Office Equipment & Supplies
I hava a canon dr-2010c scanner. but when I scan the paper through capture touch 2.0 than scanning very fine but when I scan through capture perfect 3.0 than show black page scanning.
Normally it is advisable to use only one Scanning Software. The software has various files which may overwrite the previously installed version. The later version works good.
It is also possible that the brightness/contrast settings in Captureperfect 3 is not proper. Try scanning after altering these.
S. Mohan, India
Apr 03, 2014 | Canon DR-2010C Flatbed Scanner
Capture barcode at scanner Canon Dr 9080C
You will need to purchase the CD "Canon Barcode Module III" and install it on your computer: Mfg. Part: 1922B001
Then you can select it in Canon's document scanning software/Capture Perfect.
Scan-R-Store
Dec 10, 2013 | Canon DR-7580
Won't scan to PDF with Capture Perfect 2.0; Error
There are two versions 2.0 and 2.3. One of them converts to PDF without PAFCV2.dll load error. Try and down load from http://software.canon-europe.com/software/0022439.asp?model= Incase this doesnot work, you need the other version.
I generally dont do direct conversion to PDF. I clean the images, create multipage and then convert to PDF and hence don't know which version works. I have both versions. Incase the downloaded version does not work, pls send a mail to smohan54@yahoo.com I shall send you a copy.
S. Mohan, Chennai, India
Oct 08, 2009 | Canon DR-2580C Path-Through Scanner
Acrobat and Canon DR-9080C not working
You are right, it is driver related issue. Acobat 9 has more features that may not be compatible with the existing driver. may be you can use CapturePerfect and directly create PDF and then use the Optimising features of Acrobat 9. Ofcourse you have to do it twice, but you can use the 'batch' process and do it automatically.
S. Mohan
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
When ever I scan, Capture Perfect adds zero's to
On the screen "scan batch to file setting" in the middle of the page under "save as type" change "type of batch separation" to "none". This will fix the problem.
Apr 24, 2009 | Canon PIXMA MX310 All-In-One Printer
I have a canon DR-9080c that gives me a PAFCV2.DLL load error
I have resolved this in the past and a new user just brought it up again.
The pafcv2.dll in Captureperfect 2 does not seem to work. If you install CapturePerfect 3 and copy the pafcv2.dll into captureperfect (c:\program files\canon electronics\captureperfect2 or whatever install path you used), you will find that you can now scan into PDF, even in batches!
Feb 23, 2009 | Canon DR-9080C Path-Through Scanner
Cannon capture perfect 3.0
Check the location where you are directing the scanner/computer to store the scanned image. If it is full, obviously it cant store. Change the location where there is space.
S. Mohan
Oct 14, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-3080 CII Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Sep 10, 2008 | Canon DR-3080CII Path-Through Flatbed...
Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Jan 31, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-2580C Path-Through Scanner Logo
2,162 people viewed this question
old marine
old marine
