Question about Toshiba 62HMX84 62" Rear Projection HDTV
No red how can I get into service mode to adjust the red on a toshiba 62hm84
  • pgriff32 Feb 07, 2008
    thanks for trying . to inovled for me I need to find a tech Thanks anyway
  • Anonymous May 04, 2008
    no red
  • 2,336 Answers
Make sure you write down the settings on the TV before you attemp to make any changes.
Check this site: http://myweb.accessus.net/~090/how2adj.html#5.2
Posted on Feb 07, 2008
I have a Toshiba 62HM84, The image shutdown and started a big noise on the back, like SHSHSIIISSHSSHSISIS, please what is this can I get the Tv replaced again or it ***** definitly?
Check the color wheel. It will be best to replace the light engine. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 22, 2015 | Toshiba TheaterWide 62HM84 62" Rear...
My toshiba 62hm84 was given to me without remote control. Can I operate it without it or do need to get a remote.
The remote control for this model is no longer available through Toshiba. You can operate the set but will not be able to use the picture size features. You should be able to work the main functions and also access the picture and audio on- screen adjustments. If you find a vendor that happens to have miscellaneous remotes, the remote number is CT90164.
I hope this helps,
Skyassoc
Dec 11, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
Red Hue
Go into the service menu and turn down the red push and red cut a few notches. Write down every value in the service menu and be careful to make sure you don't change anything else. Also, turn down the brightness a couple of clicks and the red glow will be gone.
Or, try this - Press Mute on the remote control twice, press Mute a third time and keep holding at the same time, press the Menu button on the TV front panel. If you do it correctly, you will see a small S on the screen. Congrats, you are in service mode. Press Menu on the remote to get to the adjustable settings. Be careful not to change anything without writting the original value down first. Also be careful of hitting other buttons on the remote. To reduce red push, Use the channel up down button until it says RCUT. Adjust the value using the volume button on the remote. I recommend setting RCUT to 80H, which is the preset value according to the service manual. To exit Service Mode, simply power off the TV. Good luck.
Jul 04, 2010 | Toshiba 51H84 51" Rear Projection...
I just moved my 42in. Toshiba rear projectiom Tv from my basement to the upstairs and now my convergence is off. The red tube cross is low on the manual adjustment and will not go up to the other colors.IT...
It sounds like you jostled the red CRT gun when you moved the set. If the convergence adjustment still moves the red cross hair the the circuitry is okay. Your red gun needs to be realigned. This requires a service call unless you want to attempt it yourself. It is fairly involved and requires some specific tools as well as using the service mode on the remote to reset the convergence after the gun is repositioned.
Dec 06, 2009 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 62HM84 Starting Problem
you need a balist.
olso in the cust menu is a quick start mode . turn it off
Nov 18, 2009 | Toshiba TheaterWide 62HM84 62" Rear...
Toshiba 52Hmx94
How many times does it blink?
I replaced the ballast in my 62HM84 and it fixed it. The problem was TV would not turn On, Red light solid green light blinked 9 times then TV would try to restart. At first I thought it might of been the bulb, so I replaced it, same results. Next I replaced the ballast which is pretty easy, just take pictures before you remove the light engine so you can go back to the picture to verify the connections when reinstalling.
Dec 25, 2007 | Toshiba 52HM95 52" HDTV Projection...
Still green
go In service convergence mode and try to adjust red and green if you cant then it's convergance amp ic's
if you can adjust them so they align up try doing a touch fous after that,.
Dec 16, 2007 | Toshiba 42H81 42" Rear Projection...
Can't adjust the value of the width in Service mode ' WID '
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 05, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 convergence problem fixed but now vol.is gone
I just posted a question about a convergence problem( juice07 ). I am unable to adjust the red color in the convergence adjustment mode. Did you have a similar problem ?? Please help.
Sep 28, 2006 | Toshiba TP50H50 50" Rear Projection...
Toshiba 62HMX84 62" Rear Projection HDTV Logo
50 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
