Question about HP LaserJet 3050 All-In-One Printer
Troubles with copying
I have a line in the middle of the page that I am copying.
on a hp laserjet 3050.
  • mdsander Feb 16, 2008
    copying- the copied paper has lines on it .
  • Anonymous Feb 20, 2008
    line down the page when I copy
Pull the Top Loading Document Feeder up towards you from the back, to open and view the clear strip (perspex). I also had this problem, and fixed it by cleaning this strip. for future reference don't use whiteout on papers your going to fax/copy ;)
Posted on Jun 17, 2008
    Habit-Forming:
  • 59 Answers
If your print jobs direct from the computer or faxes received come out ok then you probably have some dirt on the optical reader.
This is where the paper goes through the machine and is read by the printer and either reprinted or faxed. Pop open the top cover and you will see a clear strip (perspex) going from side to side, check this for any dirt or stick stuff and clean it off.
Posted on Feb 19, 2008
Only scanner problem , horizontal lines appeared during scanning
No PC model stated
no OS stated (opr. system) windows 10?
we can not help you, ever lacking key facts
why not go to your HP support page and load all software
Related to Laserjet 3050
here
https://support.hp.com/us-en/drivers/selfservice/hp-laserjet-3050-all-in-one-printer/1140783/model/1140778
Aug 06, 2017 | HP LaserJet 3050 All-In-One Printer
Everytime I fax something on my HP Laserjet 3050, the recipient receives the document with a line going down the middle of the page. How do I get rid of the line?
The way this ADF works is that there is a stationary scanner head and the machine moves the paper over it. The line down the pages is due to debris stuck between the page and the scanner. The ADF panel should open to show you the glass that needs cleaning. See the link below for full instruction. You should be able to test this by making a copy.
Jun 14, 2010 | HP LaserJet 3050 All-In-One Printer
Printing black line down middle of page when coping
The fuser is located in the back of the printer. I think it's held in by to screws. It's about hte same size as the toner cartridge. Please visit these websites.
This is the fuser kit.
http://store.printerprinciple.com/products/rm1-3044
The service repair manual.
http://www.scribd.com/doc/15253671/HP-Laserjet-3055-Repair-Manual
Fuser Replacement is on page 170.
Aug 08, 2009 | HP LaserJet 3050 All-In-One Printer
Printing black line when coping
You may need to replace the toner cartridge or the fuser assembly.
If you open the toner cartridge door and see a black line on the roller, you will need to replace the cartridge.
Aug 07, 2009 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
HP 3050 vertical black lines during fax
OK, from the desciption i can assume several things here are some option.
If by receipt you are talking about the confirmation the unit prints the the problem is likely dirty glass.
You would also get the lines when you make a copy using the ADF.
Open the lid there are two areas of glass the thin strip is likely dirty and needs to be cleaned.
If by receipt you mean pages you receive from someone else, and not printed or copied on your machine, then their machine has the condition described above.
If everything has the lines then you have a toner or fuser problem:
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Mar 24, 2009 | HP LaserJet 3050 All-In-One Printer
Black lines on printed material
check the optics section the remove the exposure glass anh clean the fisrt,second, and third mirror
Feb 16, 2009 | HP LaserJet 3050 All-In-One Printer
Solid Line on left Margin after Copy/Scan
When I Copy or Scan with my HP LaserJet 3050, a solid black line appears on the left margin of the page. . Can you suggest any solution to the problem. .
Oct 29, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
152 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
