Home | Krups | XP 1500 Espresso Machine & Coffee Maker | Coffee out not same as ...
Krups XP 1500 Espresso Machine & Coffee Maker
Problem for Krups XP 1500 Espresso Machine & Coffee Maker
Coffee out not same as amount of water in/no steam
By bafratto on Feb 07, 2008
I put 8 cups of water in but only get 6 cups of coffee
Have to heat the milk in the microwave
Solution #1
posted on Feb 08, 2008
Not Rated)
pierre235
Rank: Guru
Rating: 87%, 820 votes
you have to descalcify the machine not with vinegar .vinegar removr calcium in little pieces and might block the machine descalcifier melt the calcium on the heating element you have lots of calcium that mean less heat you use 1 part descaler 1 part water put in water containerstart the machine for a few second turn off for 10 minute if you never descaled the machine leave it for 15 minute and repeat untill empty rince very good a few water container that stuff is very corosif after a good rinse try the coffee it should be good thank you for using fixya pierre
Was this helpful?
Yes
No
Popular Solutions for Krups XP 1500 Espresso Machine
Questions and Unsolved Problems for Krups XP 1500 Espresso Machine
Do you recommend Krups XP 1500 Espresso Machine & Coffee Maker?
Answer
Answer
Hi, I just purchased the Krups XP1500 Coffee and Espresso Combi Machine. The coffee side works... (More)
Answer
I fill the 2-cup thing full to almost the rim, then mash it in using the circle on the end of the... (More)
Answer
My coffee and filter are in place, the water is in, the bottom gets very hot....but no coffee... (More)
Answer
how do you assemble the axle and the filter holder into the xp1500 expresso and coffee maker?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Krups XP 1500 Espresso Machine...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
