Question about Yamaha DSPE390 Amplifier
Carver m500 Anyone know how much power out put for the transformer M500. there are two orange and two red wires. What ia there output rating? Is there anynone having shematics of M500 carver?
    Novelist:
    Scholar:
  • 96 Answers
Hi, first it's not power, it's the voltage you need to know, is the transformer burt, if not you can mesure the voltage output by putting a voltmeter at the primery to see if 120vac is there and then the output to see how mutch at each two wire at orange is and then at the two red is. They should be about 24vac on orage and 60 volts at the red.
Not shure what the voltage just guessing, if totaly dead then you have a burt transformer, some of these unit have a internal fuse, you may see them on the top, they may be also thermal shutdown sensor's fuse type, look to see if there is one, if so look at there value, thermal has a degree in C for the value and pico fuse has amp's or ex 4a .
I hope this help
Bob
Posted on Feb 08, 2008
Tip
How to measure Voltage in Transforme for Fitness Treadmill
Transformer Test Procedure:1). Make sure that transformer wire connections (CON1) to the drive board are secured. Turn unit on.2). Put multimeter to the AC voltage setting. Insert meter probes into the transformer primary (red)wires as shown. Normal reading: 110V. This shows that there is power to the transformer.3). Test transformer output by probing on secondary (output) wires: black and black, white and white,orange and orange, yellow and yellow
Transformer Test Results :1). If there is no voltage across the primary (red) wires, inspect F1 fuse on the drive board and power to the drive board. 2). If there is voltage across primary wires but none across secondary wires, the transformer is bad.Replace it.
Transformer Wire Colors Normal Voltage Value:
Red and Red 110 VAC.
Black and Black 11-13 VAC
White and White 11-13 VAC
Orange and Orange 27-29 VAC
Yellow and Yellow 10-12 VAC
on Oct 26, 2011 | Exercise & Fitness
Tip
How to measure Voltage in Transformer for Fitness Treadmill
Transformer Test Procedure 1). Make sure that transformer wire connections (CON1) to the drive board are secured. Turn unit on.2). Put multimeter to the AC voltage setting. Insert meter probes into the transformer primary (red)wires as shown. Normal reading: 110V. This shows that there is power to the transformer.3). Test transformer output by probing on secondary (output) wires: black and black, white and white,orange and orange, yellow and yellow.
Transformer Test Results:1). If there is no voltage across the primary (red) wires, inspect F1 fuse on the drive board and powerto the drive board.2). If there is voltage across primary wires but none across secondary wires, the transformer is bad.Replace it.
ValueRed and Red 110 VAC
.png
ERNESTO CUADRA
MANAGUA, NICARAGUA. C.A.
I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Mar 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
Will this amp push 2 2000 watt subs?
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
Unlock spv m500 mobile phone
Use unlock code to unlock your mobile....Get the unlock code here http://www.wickedunlock.com/unlock-your-phone/rs11wp2/ and also get the unlock instruction in the same site....With the help you can unlock easily....
Feb 08, 2010 | Orange SPV M500 Smartphone
Alpine MRP-M500
You need to check the Fuse on the Power Wire and check the ground wire to see if has loosened up. Also check Power Wire as well.
Hope you see what you are your looking for! Good Luck!
If you have any more problems let me know.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this answer!
Jan 10, 2009 | Alpine MRP-M500 Car Audio Amplifier
Power supply M500 carver
check the output transistors
Jan 07, 2008 | Audio Players & Recorders
Yamaha DSPE390 Amplifier Logo
333 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
