Putting in a new drum/ APVC Correction
I am putting in a new drum and the instructions say to execute an APVC correction. How do I get into the Copier function menu to do this?
  • JAYESQ Feb 08, 2008
    It is a Canon IR 2800. I did breakdown and purchase a service manual for it. I think that I got it done correctly. Thanks for the response.
  • 1,326 Answers
What kind of copier is it? Is it a Canon? It sounds like it is, what model is it? There are diffent ways to get in to service mode. Basicly, the APVC put a charge on the drum to level it out, to off set the surface of the opc drum, to offset any ambent temputures the drum was exposed too. You can also run a sky shoot and then do your adjustment.
Posted on Feb 08, 2008
Error c2814
The proper value cannot be figured out within the specified time by the correction of the patch density correction /K. Or, the proper value of the developing DC output is 0 or lower.
Associated Parts:
• Printer control board
(PRCB)
• Developing unit /K
• IDC sensor (IDCS)
• IDC shutter solenoid
(SD3)
Remove the black (K) Drum. behind and toward the front is a silver/chrome looking thin bar with a tine square that square is a sensor clean it or replace the drum (switch different color see if changes codes) or switch out sensor with a different one each drum has one when was the last developer was replaced for black getting close to a PM???
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 12, 2015 | Konica Minolta Bizhub Press C6000 Copier
Change drum
If copier is saying to replace it. Will need to by a photoconductor unit then open right side door then open front door pull toner assy out ward and on photo unit front bottom press on latch each side and pull it out to remove it. There might be instruction after putting new one in to run a initialize code
Jan 23, 2014 | Ricoh Aficio MP 1600 Black and White...
Toner NOT sticking to paper
"Cars & Trucks" is not the correct place to post your question for your Xerox XC1044 Copier. However, I can tell you that the heating element in your drum assembly is most likely defective. That is why the toner is not sticking...it is not getting hot. You will have to replace your drum assembly to fix it.
HINT: on an older copier/printer like the XC1044, it is usually just as expensive to replace the drum assembly as it is to buy a new copier/printer. You should probably shop around before putting any money into it.
May 02, 2012 | Cars & Trucks
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
Correctable Ribbon not working. Even tried putting new one in
If the correction is lifting and being struck by the hammer the correction tape may be on wrong, the dull side must face the ribbon. The other easy possibility is that the ribbon is very old or non correctable. It should have a yellow or orange knob not red or blue.
DickyO
Mar 26, 2011 | Brother SX-4000 Typewriter
Panel shows error code Cof24
(Automatic Image density Correction) basicly this sensor looks at the drum and determines thew drums ability to hold toner and image. The sensor could have toner spilled on it or the drum needs to be replaced or the senor has gone bad
May 29, 2009 | Minolta EP1030/1030F CS/PRO Copier
Need to execute APVC Correction in Service Mode
You must press *28* for service mode, but no APVC correction is no needed.
And if just want to do it any way be sure to put A3 paper in second drawer, because drum adjustment.
Apr 14, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon ImageRUNNER 300S - Replace Drum
All you have to do is have a phillips screwdriver and remove the screw that secures the drum to the copier. Before removing the screw you need to release the developer unit out of the way. Just perform the same procedure as if you were going to put new toner into the copier but you don't have to pull out the developer unit. Then just to left is the drum unit and at the top of it should be a black screw. It will be about an inch long. Then just pull out the drum and put in the new one after removing all the packing material. Be sure to not touch the round cylinder of the drum unit, that is the drum. Also, you may want to practice put in the old drum several times before putting in the new drum until you're sure you can put in the new one without damaging it. There is another thing that should be done but that is a technician thing and is probalbly beyound what you am7y want to deal with. It doesn't really ahve to be done but a tech should do if he replaces the drum for you. It most likely would not affect copy quality and will not hurt the drum if not done. Good Luck and be careful.
Oct 16, 2008 | Canon NP 6050 Copier
F2 error
"F2-31" Image density sensor fault "F2-32" Drum mark sensor fault "F2-33" Grid voltage correction problem "F2-35" Grid voltage correction problem "F2-37" Drum mark sensor fault
Sep 03, 2008 | Sharp Office Equipment & Supplies
Changing the drum on a Canon NP-4050?
1- open front door
2-on the right side put lever down ( disengages developer to drum)
3- swing toner holder ( dispenser ) to the right
4- bring green lever down ( has two belts )
5-unscrew the gray screw and pull out the unit ( this is the drum UNIT)
6- replace and do all the steps backwards EXECPT
7- put a pencil or paper in a slot on the right to cheat the contact and turn on the machine
8-on the left side under the counter there is a small hole insert a paper clip to engage service mode
9-there are two numbers on the new drum.
10- go to primary and set the drum primary then go to the next number and insert that.
11- go to apvc and select that
it should rotate and stop ttake out cheater and make a copy
good luck
Nov 08, 2007 | Canon NP 6050 Copier
k24674
jasbo
jasbo
Marvin
Marvin
