Back to:
Tags:
Sony PCV-RS620G PC Desktop
PCVRS620G won't turn on (by 3 users)
posted by LG2U on Feb 07, 2008
Checked power supply and it is good. I can hear the fan running but the unit will not power up.
Comment by LG2U, posted on Feb 08, 2008
Ok I have now replaced the RAM with no change. I can hear the HDD trying to boot.I hear no beeps My monitor reads no signal, but this is always the case until the unit boots.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by superbob2, posted on Mar 17, 2008
hmm... yeah i have the same problem with my rs620g
ive tried the same things that you have and it doesn't work
Comment by Guest, posted on Feb 11, 2008
i have replaced the ram and graphics card, the monitor and cable work fine on another computer. Any i deas?
Clarification Request
by aceltix, posted on Feb 07, 2008
tell me more..like..some pc speaker sounds?no image on  screen?do you hear the HDD running?because untill now..it sounds like a video card problem..lets clear this to understand if there really is the VGA fault.
Best Solution
Helpful (85)
aceltix
Rank:Guru Guru
Rating: 87%, 118 votes
a computer without ramm...hmmit depends...however without VGA..never..better check both ram and vga..
Rating Locked! (?) LG2U has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on PCVRS620G won't turn on:
I don't want to Accept this solution
Solution #2
Helpful (85)
vimlendu
Rank:Guide Guide
Rating: 90%, 11 votes
i feel this is not a big problem. if u hear a beep of ram on beap on boot then ram is ok just short it and check for displaay. check ur cpu socket it may be loose. if u don hear a beep on boot change the ram and ur problem will be solved
Thank You!
Solution #3
posted on Jun 01, 2008
Not Rated (0)
woods420
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Same thing is happening on my rs620g. It started after I was cleaning it with air and uncliped the fan over the cpu to remove it and the cpu came off with it. I put it all back together correctly and mine will power up but make no beeps. I checked ram and video card. Both are fine. What did I do the cpu chip? Do I need to grease it? There was still some there.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #4
Not Rated (0)
Guest
Rating: 0%, 0 votes
i replaced the ram, vga card at this point. The monitor and cable works fine on another computer. Could this be a mother board? I see a green light on the mb. The HDD is trying to boot but w/o display i can't confirm.any ideas?
Thank You!
Can you Help with these PC Desktops problems?
PC Desktops
locked out from pc? forgot password? how to change...
PC Desktops
Please note that i am trying to restore my Advent T9100...
PC Desktops
comuter is locked, cannot unlock, cannot turn off, message...
PC Desktops
will not boot up past start screen
PC Desktops
everytime i move my laptop it locks up and turns its self...
Loading problems.
Repair Service
Find PC Desktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
