FixYa.com
Tags:
Toshiba 120GB  5400rpm 8MB Notebook  [HDD2D16 9.5MM] 120 GB Hard Drive
When I plug in the HDD16 into the USB my computer...
posted by Dazlee on Feb 07, 2008
I have so many photos and files on my external drive, but every time I now plug into the USB on my laptop or any other computer it says USB devise is not recognised?? Can you please help.
Regards
Darren
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 07, 2008
Helpful (85)
map9966
Rank:Guru Guru
Rating: 88%, 1055 votes
Please clean the usb cable. Use a cotton swab with Alcohol on it. (Not dripping). You may need to use a few. If that fails to help, try another usb device in your PC & check if the PC can see that device. The cable could be defective. The FAT on the drive could have been damaged or the drives file system could be corrupt. The usb port could be loose from plugging in & out. If your OS is Vista that can be the problem. Try a Pc running XP.
Please check these links for more options.
http://support.microsoft.com/kb/871233 Try this as well.
http://www.hat.net/geeky/node/221
Post back & we'll go from there!
please vote after everything...
Rating Locked! (?) Dazlee has rated this solution as Helpful
Can you Help with these Hard Drives problems?
Hard Drives
my precious files...
uh... just wanna ask you guys... Answer This...
Hard Drives
USB Plug and Play stopped...
My Beyond Micro 250GB Mobile... Answer This...
Toshiba 120GB (MK1234GAX) 5400rpm 8MB...
Award bios cannot find or...
No sign of the Toshiba MK1234G... Answer This...
USB Hard Drive Problems
HI, I have a TOSHIBA MK1234GAX... Answer This...
120gb toshiba external hdd pwer...
when i plug my device to either... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
