Question about Belkin (F5D7230-4) Router (587009)
Setup of municipal wifi
I have a belkin f5d7230-4 wireless g router, and when i type in '192.168.2.2' in the address bar, it asks me for the user name and password. i'm pretty sure my son reset those values, but he doesn't remember. i've tried the defaults [belkin and admin, and admin for the password], but it tells me i'm not authorized to view this page. how can i either reset or find the user name and password?- and is that even necessary to log in- my area is wifi ready, and i have an active account with earthlink, which happens to be the provider for the municipal wifi in my area [philadelphia, pa] HELP!!!, please!
thank you, david small
sosna.1@netzero.com
  • david small
    david small Feb 12, 2008
    i think i already tried leaving the password blank, but probably not with the correct value in the user name- so i'll try it again. i intend to use this device instead of the piece of **** syslink [wrt54g] wireless router my isp wants to send me for municipal wi-fi. wish me luck, and again, thanks
Sounds good, i think i tried leaving the password blank, but i'll try it again. i intend to use this for municipal wi-fi, instead of the pos [oeice of ****] syslink router [wrt54g v.4]my isp provider wants to send me. wish me luck, and thanks again.
Posted on Feb 12, 2008
  • 38 Answers
It sounds like you'll need to reset the router to factory defaults, here's how to do this:
With the router powered on, press and hold the reset button for exactly seven seconds, this will restore the router to factory default.
Note: By default the password on the router is left blank, and the
default IP address is 192.168.2.1
Hope this helps!
Posted on Feb 09, 2008
How to setup wifi password
My Friend,
You can follow these steps to setup a wireless password.
>Connect your computer with a Ethernet cable to Slot number 1 on the router.(please don't connect to the internet port.) Just go to command prompt on your computer by typing CMD on RUN. >Type Ipconfig there and then you have to look for ipv4 address. >In this address search for the default gateway on the computer. >Type the address in the default gateway into the address bar on the browser. > Then this will ask you for the user name and password . Leave username blank and in password type admin. You will see the router set-up page . Go to the wireless tab and below that you will see wireless security tab. There you can name your network by changing name under ssid. And select the security type as WEP OR WPA. create the password fro you wireless . click on the save settings.
Hope this will help you.
Sep 10, 2011 | Linksys Wireless-G WRT54G Router
How do I rename my network on a Belkin router
Please open the configuration page of your router by typing your router's IP address on a browser's address bar. Router's IP address is the default gateway when you check the IP address on the command prompt. As soon as you are on the login page, type the user name and password. Look for the wireless settings tab. SSID is the router's wireless network name. Replace the SSID of the name you want for your wireless network and apply the changes.
May 21, 2011 | Belkin (54G F5D7230UK4) Wireless Router
Need to set up security key for wireless access. Have dlink WBR1310 router, but no longer have the CD that came with it. Recently had laptop repaired.
once connected to the network type 192.168.0.1 into your address bar in your browser.
Username is admin
Password can be left blank
Click wireless network settings. Use the wizard.
Mar 03, 2011 | D-Link dlinkgo Wireless N 150 Router...
I hooked up my router but it doesn't finish the setup
if u are not able to set it up using the CD just dont worry about it ... just start the router and scan the laptop for wifi routers select ur belkin and than click on start > run > type cmd a block window will open ... type ipconfig in that window ... write down the default gateway address and open the internet explorer and type that address it will ask u username and password ... put in the default user name password which is on the label on the back of the router and u will be able t access the setup page ... go ahead and configure it
Feb 05, 2011 | Belkin Basic Wireless Router
My laptop usually has no trouble connecting to a wireless router. I have just tried to connect to a friend's Belkin *which is not locked" and it asks me for a pin code - got the pin code of the bottom...
To connect to the network in your laptop without entering a PIN code, please follow these steps.
1. Connect the computer to the router with an ethernet cable in one of the grey slot in the router.
2. Open up internet explorer and clear the address bar and type in http://192.168.2.1 and hit enter.
3. You will find a belkin router setup page, In the left hand side under the heading Wireless click on Wifi Protected Setup
4. When it asks you for a password leave it blank and click on submit.
5. There change Wifi Protected setup to disabled and click on apply changes.
6. Then in your laptop connect to the wireless network without any PIN number.
Thanks in Advance!
With Regards,
Prema.
Jan 10, 2011 | Belkin Computers & Internet
Hi, my weirless those not work why? i have done the instaletion from the cd but nothing please help. thanks you.
Inoder to connect to the wireless network with Belkin Wireless router
Please follow these steps,
1. Connect your laptop and the router using an ethernet cable in any one of the LAN slot
2. Open up Internet explorer and clear the address bar and type http://192.168.2.1 and hit enter.
3.You will be logged into the Belkin router setup page
4.In the left hand side under the heading wireless click on channel and ssid .
5. When its asking for password to login, leave it blank and click on submit
6. Then change the current SSID name to something else you wish and channel to 11 and click on apply changes.
7.In the left hand side under wireless click on security and then change the security mode to 64 bit WEP and when its asking for key , type a 10 digit number (only numbers) and then apply changes.
8. Then under wireless , click on Wifi protected setup and change Wifi protected setup to disabled and apply changes.
Then you can scan and connect to the wireless network in you laptop then you will be online.
I'm sure it will work.
Thanks in Advance!
With Regards,
Jan 06, 2011 | Belkin Basic Wireless Router
Wired conections work fine...but the wireless connection will not work at all...the wireless light on the router just flashes red??
In Belkin routers the wireless light will be turned on Green only if you have any wireless devices is connected to the network so I belive You do not have any wireless computer connected to the routers network.
Please folloew these steps to connect to the nework,
Thanks in Advance!
With Regards,
Prema.
Jan 06, 2011 | Belkin F5D7234-4 Router
Belkin Play N600. Acer Vista laptop. Wifi only, laptop wifi connects then disconnects. With ethernet connected the wifi and ethernet shows connected, when unplugged, the wifi will disconnect also.
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Dec 24, 2010 | Belkin Play N600 Wireless Dual Band Router...
How to secore my wifi i dont the user name and password what can i do..? please help me....!
OPen Router Setup Page by typing 192.168.2.1 in address bar of any webbrowers like Internet explorer or Safari If you not able to Belkin Router Setup page through Webbrowser then,
Clicl on START>ALL PROGRAMS>ACCESSORIES>RUN
then type in RUN window http://192.168.2.1:80
Select Security
NoTe it may ask for password, by default no password so you can leave the box blank and then click on submitvargheseacer_1.jpg
Then select WPA/WPA2
Now type the password here
Now your router is secured and no one can share your internet until or unless you provide the password
Dec 14, 2010 | Belkin (F5D7230-4) Router (587009)
Hi i have a Belkin G router and i can't acess the inter on my laptop could you please help, I dont know what to type in for my user name and passsword also domain please help
Step 1 : Connect Router - Computer ( Wired )
Step 2 : Open RSP By Typing 192.168.2.1 on the Address Bar of the Internet Explorer
Step 3 : On the Left Side Under Wireless Click WiFi Protected Setup
Step 4 : Leave the Password Blank And click Submit
Step 5 : Disable it And click Apply Changes
Step 6 : On the Left Side Under Wireless Click Security
Step 7 : Make a note of the Password ( PSK or Pre Shared Key )
Step 8 : Restart the Router
Step 9 : Now try to connect
Step 10 : If its Working Let Me know
Dec 25, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7230-4) Router (587009) Logo
188 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
