Question about Samsung SCH-u540 Cellular Phone
How do I turn off Alarm only
I somehow set my phone to "Alarm Only". The icon has an alarm icon with a line through it and a clock like I'm away. Phone will not ring. Can't find answer in manual. It tells me what the icon means but not how to turn it off!
Thanks for your help!
  • Anonymous Apr 22, 2008
    Same problem, did you get an answer?
  • Anonymous Mar 13, 2014
    i have an icon of 3g on the top line of my cell phone and dont know how to turn it off that the icon goes away can you help me
On the left hand side of the phone (on the side) there are up and down buttons. Push the button up and it will change the ringer status
Posted on Apr 04, 2008
Alarm on notification bar
If you open the clock app and click on the alarm page, you should see all the alarms you have created, if any of the little alarm icons next to them are green it means that that alarm is enabled, tap the icon to turn off the alarm, this should make it go away.
Jan 17, 2016 | Samsung Galaxy S5
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
Accidently activated the alarm clock on Gigaset phone A400/A400A and now I cant work out how to deactivate it. Sorry cant understand manual it doesn't seem very clear to me. I am a 67 year old pensioner so...
Hello
This tells you how to set it, but not how to turn it off, so my guess is that once set, and the alarm goes off, it is then turned off. Or, there is a toggle on it, so press OK to Set, and OK again to Disable. The sequence is
Menu ₪ Alarm Clock ₪ OK ₪ Activation ₪ OK and I reckon OK a second time to switch OFF
Setting the alarm clock
Activating/deactivating the alarm clock
Menu
Alarm Clock
OK
Activation
OK
= activated)
If activated
Enter wake-up time
OK
When the alarm clock rings, press any key to switch it off for 24
hours. If the alarm clock is set, the wake-up icon will appear on the screen and the wake-up time will be displayed instead of the date.Entering/changing the wake-up time
Menu
Alarm Clock
OK
Wakeup time
OK
Enter the wake-up time in hours and minutes, then press
OK
. The alarm clock is automatically activated after the wake-up time is entered/changed.
It is easier to read on Page12 of the manual.
Good luck
Andrew, age 65 (almost)
http://gse.gigaset.com/fileadmin/legacy-assets/A31008-M2201-L101-2-7619_en_UK.pdf
Dec 10, 2017 | Lands Phones
Samsung ch@t 335 alarm not working.
Make sure you have correctly set your time and date of your phone. By "correctly", I mean double check that "AM/PM" thing.
Jun 11, 2017 | Samsung Cell Phones
Alarm icon is displayed in the center of the screen no matter what I do. All alarms are turned off. I've rebooted the phone several times including removing the battery. What else can I do?
I've had this same weird problem today but I think that I may have solved it.
1. Go to "Menu"
2. Go to "Settings"
3. Go to "Display and Light"
4. Go to "Widget". Among your widgets is one called "Analog Clock". Un-check it and Save the widget screen.
5. Go out of the Menu to the top screen (that has "dial", "contacts" and "menu" at the bottom.) Hopefully, the alarm icon is gone. However, the "Analog Clock" that displays the time in the widgets (opened by the small arrow on the left side of the screen) is also gone. Simply go back through steps 1-4 to get to the "Widgets" screen and check the "Analog Clock". Your Analog Clock should display and the Alarm icon should still be gone.
I know that this solution doesn't seem to make much sense because what does an Analog Clock have to do with an Alarm icon? It just seems to be a software glitch of Samsung.
Try it out and see if it works.
Aug 14, 2010 | Samsung Solstice SGHa887
We have this HM3817DT CD radio and somehow the alarm setting was bumped and it goes off regularly and we don't know where to shut it off. The instruction manual says nothing about setting or turning off...
When you press the AL SET/ SLEEP button on the remote or the system, it will flash. If you press it again, it should go away, meaning it is turned off.
May 01, 2009 | GPX HM3817DT Shelf System
2 alarm times appear at the bottom of my screen. I only want one
I had the same issue. For the last few days I had the double alarm icon with the one you describe showing 8:00 am. I had no alarms etc set so I had no idea what it was until today at 8:00! A notice came up about a friend's birthday. Apparently when I was in my calendar a few days ago I attempted to put the birthday reminder on my calendar. In the menu I thought I selected "New" however just above the New option is the New Alarm option which is what I must have selected. When the alarm came up the icon went away from my home screen and the clock page. I went in and deleted this recurring alarm and scheduled it as I normally do on my calendar.
You probably have an alarm that either already came on by the time you have read this and you likely set it inadvertently like I did. I hope this helps.
Mar 15, 2009 | RIM BlackBerry Storm 9530 Smartphone
Sony dual alarm am/fm alarm clock radio
HOW does one set the time and alarm on a "sony dream machine clock radio"?
Aug 28, 2008 | Sony Dual-Alarm AM/FM Clock Radio with...
Alarm clock won't ring - Verizon v3m
what you can do is go to ringtone settings and assign a specific tone to it....and then test it
May 26, 2008 | Motorola Mobility RAZR V3
RCA RP3721 Alarm won't shut off
To turn alarm off completely, press WAKE1 and WAKE2 until the bell-shaped indicators go off.
As for resetting the alarm (buzzer), press SET WAKE/CLOCK untill SET and WAKE! light.  Press left- or right+ arrow to set time.  Press WAKE1 until bell-shaped indicator comes on.
Jun 14, 2007 | RCA RP3721 Clock Radio
Samsung SCH-u540 Cellular Phone Logo
173 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
