When logging on the black windows screen displays and the loading bar looks like it is trying to load but just keeps going back and forth and never loads
You might like to Power it off completely by removing the Battery for a few seconds.
If that doesn't help, try booting from your Win7 Installation Disk.
Presumably you see items on the screen while the os is loading and you are able to see the login prompts?
If this is a windows OS start it up in safe mode (tap f8 when first turned on to get a boot menu) to see what happens. Sounds like a resolution issue. If windows opens in safe mode look for evrror messages in the system logs relating to graphics gards or look at lowering the graphics resolution, also try attaching an external monitor. Post back if you get stuck
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
try recovery console enviroment using your your windows vista cd while booting in cd go to repair then it will repair your windows or go to recover to last working state or go to command prompt then type this SFC this will look for corrupted system file and try to recover it still . you can search it to google how to do it or try reformat your hardisk then install a fresh windows install hope it solve your problem
The error refers to a bad Hard Drive. You need to call up Dell to have the Hard Drive replaced. Make sure to start contacting a Local Pc Shop to help you back up files from your Hard drive since Dell doesn't cater to backing up of data on any Hard Drive.
