Question about Samsung LE40R74BDX 40 in. LCD Television
How to remove the stand from samsung LCD TV
I want to fix a wall mounting to my tv for the bedroom and wish to remove the built in stand so that I can fix the wall mount versa fitting stand. Can you help?
  • Anonymous Mar 27, 2014
    wall bracket slots will not slide over TV
    bracket
    wall mount bracket doesn't fit tv bracket
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Posted on Feb 09, 2008
I HAVE A LN-S4095D TV THAT WAS WALL MOUNTED NOW I WANT TO GET A STAND THAT WOULD SUPPORT THE TV ON A TABLE. I DISCARDED THE ORIGNAL STAND WHEN WE WALL MOOUNTED THE TV
Good luck with that. As soon as these sets go out of production, so do most of the parts associated with them. You would be better served to get a TV table stand that uses a wall-mount-style backer. That way you get the tabletop mount and the extra security of knowing it won't get knocked over easily. Something like this....
Aug 10, 2016 | Samsung LN-S4095D 40 in. LCD HDTV
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
Took it off the wall of the camper we just bought. Would like to use it in my guest bedroom, but the stand is gone. Can you help locate one for me?
If you search on Ebay for your TV's exact model number, sometimes you can find a replacement stand for it there.
Here is a link to one example currently available for an Emerson TV:
http://cgi.ebay.com/Emerson-LC320EM8A-32-Inch-LCD-Flat-Panel-TV-BASE-STAND-/110728286130?pt=LH_DefaultDomain_0&hash=item19c7eb8fb2
Otherwise you can just buy a generic wall mount floor stand for around $100 which bolts to the TV like a wall mount, but actually sits on the floor instead of being bolted to the wall.
Here are some links to a few different models currently available on Ebay which include pictures so you can see what I mean:
http://cgi.ebay.com/PLASMA-LCD-FLAT-PANEL-MOUNT-TV-STAND-WALL-SHELF-STAND-/390330001764?pt=LH_DefaultDomain_0&hash=item5ae17b2964
http://cgi.ebay.com/Plasma-LCD-Flat-Panel-Console-Shelf-Wall-Mount-TV-Stand-/270797719452?pt=LH_DefaultDomain_0&hash=item3f0ccd479c
I hope that was helpful to you, good luck and take care.
If you choose to rate this solution by clicking on the YES THIS WAS HELPFUL icon, I thank you very much for your time and consideration.
Joe.
Aug 11, 2011 | Televison & Video
Need a stand
I could not locate a stand for purchase on http://www.partstore.com/Model/Samsung/Samsung/PDP4294LV1.aspx
By the way, your tv is a rebranded Samsung model.
Without the stand, you only option would be to wall mount the tv.
You can purchase a wall mount for your tv from your local Wal-Mart or something to that effect for around $30.
Mar 13, 2011 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
How do i remove stand from samsung syncmaster 2333 to mount on wall
its a snap-type plug-in stand, just hold the stand firmly and pull the monitor equally upward, then it will snap quickly....... but a proffessional reminder! Before mounting your SyncMaster on a wall, be sure to plug the two (2) stand holes located at the buttom of the monitor. My Samsung SyncMaster 2333HD LCD TV was twice intruded by adult-size lizard, both incident resulted to main power board damaged!!!!
Feb 13, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Tv stand on the wall
It is not made for wall mounting unless it has 4 bolt holes in the back cover. Some wall mounts grip the tv on top and bottom, but they look like hell.
I bought the same Samsung, but took it back.
Dec 28, 2008 | Samsung SyncMaster T200 LCD Monitor
Cannot figure out how to remove stand so I can mount TV on wall
did you figure this out? I only ask because I need the stand for my TV. Could you sell me yours?
Thanks
Anthony
amsaxo@yahoo.com
Dec 02, 2008 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Jul 22, 2008 | Sylvania LC320SS8 32 in. LCD Television
Samsung LE40R74BDX 40 in. LCD Television Logo
3,586 people viewed this question
Henry  Thomas
Henry Thomas
