the epson scan app won't even open despite being re-installed on my mac. can't seem to find any options anywhere to help or even to import using cs3???
-   I am having the same problem which also came out of nowhere. When i went to click on Photoshop for the application for it to use it says the photoshop does not recognize that file type. HELP!-   editor in ne
May 15, 2008
-   I am having the same problem. The scanner worked perfectly for a year and now all of a sudden I am getting the error message "Epson Scan cannot be started". I've tried reloading the software but nothing is solving the problem. Any advice?-   Paul3456
WARNING: IF YOU ARE NOT FAMILIAR WITH THE REGISTRY, DO NOT ATTEMPT THIS.
and for the person getting "Epson scan cannot be started. That is a comm error. Check your connections and rinstall the software. Do not attempt the following
1. Click on START and then RUN. 2. In the Run window type in REGEDIT. 3. In the upper menu bar click on FILE, then EXPORT. 4. In the window that comes up, SAVE IN should be set to DESKTOP. 5. In the FILE NAME section at the bottom of the window type in REGBACKUP. 6. EXPORT RANGE should have a dot next to ALL. 7. Click on SAVE. 8. Look in the column on the left and Click on the “+” sign next to HKEY_CURRENT_USER 9. Click on the “+” sign next to SOFTWARE 10. Click on the “+” sign next to Epson 11. Look for a folder name EPSON SCAN. Right click on it and Delete it
Was this helpful?
Yes
No
Popular Solutions for Epson Perfection V100 Flatbed
how to scan a document into pdf using epson perfection v100 scanner? i push the pdf button, nothing...
(More)
HOW TO SCAN A DOCUMENT INTO PDF USING EPSON PERFECTION V100 SCANNER? I push the PDF button, nothing happend.
There are some fungus in side of my scanner glass. It is visible scanned pictures. How can I clean...
(More)
There are some fungus in side of my scanner glass. It is visible scanned pictures. How can I clean it? My scanner is Epson perfection 660.
