Question about Gateway FPD2275W LCD Monitor
Need help where can i get a replacement board m713-s3 for the video signal for the monitor thans the small board out of it
    Genius:
  • 3,587 Answers
Black market, maybe. perhaps you'd like to share the model/make of this monitor?
Got backup?
Posted on Feb 10, 2008
No input signal message and screen goes black
Check your video cable going from your monitor to the pc. If your trying to use more than 1 monitor, is your video card capable of using more than 1? Are you using the mother board video card or a store bought one?
Jul 22, 2012 | HP W2338H 23-Inch Widescreen Monitor
I have no signal on the screen, but does through the vga port. what it could be?
Check the choosen video input on the monitor to match the used one. Check the video cable for bended pins. Check with other monitor if there is a signal from the videocard. Check if you have connected the monitor to the right video connector, I mean, if your motherboard has integrated internal video and also there is another videocard, usually there is no signal on the internal one. Check the monitor with another computer to see if the problem is with the monitor. If the monitor is faulty, open it and check for inflated capacitors on the power supply board. Replace all of them if so. Check the buffer transistors between the video connector and the processor on the signal processing board.
Apr 08, 2012 | Samsung Computers & Internet
RCA HDTV Monitor; menu popping up and volume going down
The small signal board needs replacement. You can get replacement small signal boards from www.tvrepairworld.com
Jun 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
No power with 700P LCD monitor, No green light, nothing. replaced 2 popped 470 25C caps. Nothing else looks bad. Board 860-ALZ-M713-F
You will need to check for any pico fuses that run along those capacitor lines they may be marked as pf or nf on the pcb
Jan 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
NO video input philips 180p1
Hello there:
This normally means that the cable that goes to the computer from the monitor is not getting any signal from the video card
This is due to a couple of possible problems
the graphics card is not compatible with the monitor
Or the graphics card is faulty or dirty and needs to be removed and cleaned with rubbing alcohol and than reinstalled
I would first try this on a different computer to see if the monitor now works if so han you know you have a graphis card problem but if it does not work than you know that the monitor is the one with the problem
It may have a faulty controle circuit on it and needs to be serviced or jut simply replaced ok
If you do take the video card out of the computer Unplug the power supply to the computer than remove the power supply cord to the mother board and press in on the power button for 1 minute this will release any esd (electrical static dicharge) that is built up during operation than attach it back on the mother board and continue to remove the graphics card and make the replace ment or repairs needed ok
I hope this is very helpful for you
Best regards michael
Dec 18, 2009 | Philips Business 170B 17" Flat Panel LCD...
Screen goes blank after being on several seconds
Is the green light on (still indicationg power? Ist put your ear to it and switch on - hear any buzzing? Most like the HV Fluro Inverter for the lamps has an issue. For some the 2SC5707 may have gone - common.
May 29, 2009 | Mag Innovision LT776s 17" LCD Monitor
Replacing old crt monitor with lcdmonitor
you will need to update a new driver for the monitor
if it's too old you will need a new video card thats compatible with the new monitor.Which i think your brtter off doing.
please don't forget to rate me
thanx
Jan 31, 2009 | Computers & Internet
Conver the signal of old CRT to VGA signal.
we use the old CRT monitor made by motorola with TTL video signal and different vertical &horizontal frequency signals than monitor with vga signal.at now we can not replace crt with lcd .is there any interface to convert this crt signal to vga monitor signal for replacing the crt with lcd or vga monitor ,beacause this crt is discontinued and the quality of video is weak.if you needs the crt specification i will post it for you.thanks.
Jan 30, 2009 | Computers & Internet
No signal
Do you have both the 24 pin plug & the 4 or 8 pin plug, depending on board, plugged into the proper places? The 4 pin plug is what powers the pci-e x16 slot. On some newer boards it will be an 8 pin plug rather than a 4. It should be clearly marked on the mb in small print. Hope this helps.
Jan 25, 2009 | Nvidia GeForce 9800 GTX,, PCI Express...
Distorted Picture
I don't think that the cable is your problem. Set may have a defective tuner or small signal board. (Tuner is soldered onto the small signal board).
Most likely fix is to find and replace the small signal board with tuner. Should be able to find one for less than $200.
Another thing to try is your video inputs. Use external devices such as a DVD play hooked you using proper video lines and check you inputs. Are they doing the same thing as your cable? If not, then it maybe just a tuner. Some makes and models won't allow you to solder in a new tuner without a full board replacement, but this however may allow you to hookup a VCR with a tuner built in and from VCR to your TV using video input jacks and then programming the VCR tuner to all your cable channels may get your set watchable again without having to tare it apart and replacing a board. However if your input jacks are distorting like the cable channels are, then a small signal board replacement is a must for your set.
Jason
Dec 29, 2008 | Sylvania 6626LCT 26 in. LCD Television
Gateway FPD2275W LCD Monitor Logo
146 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
