Maytag HAV3460AWW Top Load Washer Logo
Posted on Jan 10, 2010
Aprox 1989 model, (cant find model#) will not go in to spin cycle, just before it stoped I noticed clothing extra wet before spin quit completely. cant turn the tub by hand.
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 20, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
Helped
3826
Points
10
Model number is probably visible on small sticker on top after you take the upper rear panel off (6 screws). Water pump tends to get a loose retainer that digs into the housing and hinders then stops the free turning of the belt.
1helpful
Why are clothes/towels still quite wet after going through complete cycle?
Charlotte,
Without knowing the brand, we can only give you an idea of what might be the problem, but it obviously did not get up to the proper speed when spinning the water out since you have very wet close. If you can reply back with the brand and model of your washer, we can help you better.
I have an issue that is rather strange! On the NORMAL cycle only, at the end when it should turn off, a rinse comes on and wets the clothes. The extra rinse is NOT on, the belt and motor are fine. I know...
Always supply a model number, each model has it's own foibles. It is very hard to assist without full details.
BUT, is this an "LAT" series Maytag washer??
If so, this is a normal rinse, the manufacturer calls it a "Spray Rinse" and it is quite normal.it only adds the water during the spin cycle, after the rinse water is ejected and then only for about 1 minute, the water passing through the fabric as it passes by the water inlet flume and empties during the spin.
Clothes are too wet when finished washing. water drips from clothes.The spin cycle seems to be spinning as the clothes are against the outside wall of the tub. we have the extra spin cycle used aslo and it...
Transmission is bad. Buy new washer. Best brands are (Kenmore, Whirlpool, Maytag).
Thanks and Please Rate me! Tips provided by www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
6helpful
3answers
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Zanussi FJS 1425W - the machine is not spinning the clothes so clothes are quite wet when they are washed so have to spin but this is also not working well - washing purchased approx 7 yrs ago -
hotpoint top loading washing machine serial number TS182924N MODEL NUMBER HNXR1060T8WW. machine won't spin and will not empty water, just a humming noise. number on scamatic diagram 175D275OGO71 MACHINE IS APROX 20 YEARS OLD
1helpful
Machine won't rinse or spin properly..also stinks!
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
1helpful
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
1helpful
Clothes are still water logged after cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
From Repairclinic
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
