posted by Kjob on Feb 07, 2008
My shredder will not run forward, but will run in reverse and the automatic feed is not working
Solution #1
posted on Mar 02, 2008
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Sensor is usually located in the center of the paper feed opening.
If neither of these help your paper feed sensor or your pc
board has gone bad and you will have to contact your manufacturer for further parts availability.
board has gone bad and you will have to contact your manufacturer for further parts availability.Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Techko SH1524CP Shredder
Email this problem
Email this problem
Can you Help with these Shredders problems?
Techko SH1524CP shredder isn't...
The light is not, but there's... Answer This...
Repair Service
Find Shredder Repairman Near You:
