Question about Tricity Bendix AW1000W Front Load Washer
My Tricity Bending Washer/Dryer
Mt Washer Dryer has stopped working. It makes a screeching sound when
trying to spin and I have been told that the bearings might have gone. Are
these replacable and how much do they cost. My machine is 8 years old.
Thankyou, Maureen Alderton
  • 54 Answers
Yes they are it costs about £120 this is a major repar
Posted on Feb 12, 2008
Hello, my tricity bendix wdr1040 runs through a wash cycle just fine, but when it gets to the spin cycle it just won't stop! Any suggestions? Everything else seems fine but I worry the thing will explode...
If the answer to my last question is yes, the problem is most likely in the timer. I've had a similar problem with my washer (a different make), only it won't spin at all. When that happens, I remove the timer, carefully pull the terminal block apart where the connectors mate with the timer, and remove and clean each of the link bars between the terminal blades. The hardest part is making sure all of the link bars go back in the right places - I have to verify my work against the wiring diagram. The consequences of misplacing a link could be somewhat horrid. But then, I'd rather not pay half the price of a new machine to get a replacement timer that will do the same thing after a few years.
Oct 28, 2010 | Tricity Bendix WDR1040W Front Load Washer...
Maytag washer (model PAVT244AWW). Won't spin. Don't know how old it is or its history, as it came with a home we purchased in October. Several times it's "walked" during the spin cycle. About 6 weeks...
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Jul 05, 2010 | Maytag PAV2300 Top Load Washer
My maytag dryer was making a loud screeching noise and then stopped spinning or heating
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgsghs
Feb 10, 2010 | Maytag LSG7806A Front Load Stacked Washer...
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
WDR1041 spinning like crazy!
Usually washers go around on the floor because either they're overloaded or during the spin cycle the cloths are not balanced inside the basket. If neither of these is the case, you'll need to make sure the washer has been leveled properly. The only other thing I can suggest is to place the washer on a carpeted surface so it won't "slide" so easily.
Hope this helps.
Mar 13, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Bendix washer dryer 1054
the brushes need replaced in the motor by the sound of it
Feb 24, 2008 | Tricity Bendix AW1000W Front Load Washer
GE Model WHDSR209D2WW makes unbearable loud metal Screeching noise
ppr78, couple of things you want to check. The bottom panel on these GE's are pretty flimsy. I have run into a couple where during agitation the bottom of the motor housing would rub against the bottom panel making a terrible noise. You need to remove the front panel by pusing on the clips on the left and right side just under the top. The front panel will pull out. During agitation, take your foot and push down on the bottom panel and see if the screech goes away. I have also found the suspension rod support sockets at the top dry out and make a screeching noise. You also want to check your belt and pully and see if the noise is from there. Check these things first...Catriver..post back.
Jan 12, 2007 | GE Profile Prodigy WPSE4200A
Tricity Bendix AW1000W Front Load Washer Logo
186 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
