Question about Dryers
Dryer noise I have an electric Maytag dryer that is making a horrible noise but still drying the clothes.  It seems like something with the drum is off...is this something I could check for myself?
  • 46 Answers
Open the door and if u can lift the drum up or down more than an inch the drum bearings are worn out. big job to repair unless under warranty.
Posted on Feb 07, 2008
My maytag performa dryer is drying clothes fine and the drum is tumbling the clothes, but it is making a horrible noise. When you turn the dryer on you can hear something inside the dryer unit tumbling...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 13, 2010 | Maytag Dryers
Dryer makes loud noise during drying cycle. Drying is fine otherwise.
Bearings in the drum rollers going bad or something caught in felt area of drum. Need to take dryer apart to figure which it is.
Jun 03, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Makes a horrible noise. Seems to dry fine but before its done it sound like it going to explode.
The blower wheel may be stripped out or broken.
This will cause a loud rumble noise while operating.
Jan 16, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Dryer making horrible squeeling noise
this is normally a problem with rollers that have gotten dry bearings , take the drum out check the rollers if they turn hard or act sticky you may clean them up and and oil with turbine oil , do not use wd-40 or 3in 1 as these will dry the bearing, check the idler pulley while you have this apart also oiling it if need be
Dec 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
Noisy maytag dryer
the blower wheel sounds like it is bad it should be tight on the shaft and not turn unless the tub turns
Nov 15, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
115 people viewed this question
Top Dryers Experts
