Question about OKI B8300 Laser Printer
OKI B8300 Call for Service error
All of a sudden, our printer stopped working and is now displaying an Service Error of L6-10 - Can someone please offer any advice as to what this is ?
TIA
Simon
    Problem Solver:
  • 8 Answers
You have a bad laser, try turnuing off/on to clear,if not be prepared to have it replaced
Posted on Feb 17, 2008
  • 552 Answers
Http://www.printcopy.info/shop_e/cdrom.php?brand=OKI
Here is a link to service manuals for OKI
Posted on Feb 09, 2008
How do I fix the "change toner cartridge" error.
Has the cartridge got a chip? Does this chip need replacing?
Feb 11, 2015 | OKI B8300 Laser Printer
Oki B6250 Service Error 14....help please
I have an Oki B6250 ang keep getting a Service Error 14. When i clear all the documents pending it works but happens next time someone wants to print Its linked to 20 PCs
Nov 20, 2012 | Xerox Phaser 6100/BD Laser Printer
ERROR H5:01
HI there ERROR H5:01 mean mechanical problem. This error code says call service person for copier.
Jan 25, 2011 | OKI B8300 Laser Printer
Our Oki 8300 printer has an errror code L4-02. What does this mean?
I have an error code L4-02 with Oki B8300. what is the solution?
Oct 28, 2010 | OKI B8300 Laser Printer
Oki b4600 displays check image drum toner senror error
Try this:
Press Online
Press Menu repeatedly until MAINTE MENU displays. Press Select.
Press Item+ until DRUM CNT RESET displays.
Press Select.
Jul 01, 2009 | OKI B4600n Printer
Okie C5400 giving 162: Fatal Error
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
Toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
174: Fatal Error
I have the same problem. I had some ghosting on my pages before I got the error and turned off and turned on and it worked for a little then got ghosting again and then the error.
The technichian told me it was the fuser unit in the back. It is simple to replace, just like a drum, you pull it out and put the new one in. You can find them fairly inexpensive but check your warranty. This model comes with a one year warranty and that fuser should fall under warranty.
Feb 12, 2008 | OKI C5500n Printer
B8300 toner error
From Oki's site: Symptom: The toner counter did not clear after installing a new toner cartridge. Cause: The printer was not powered off when the new toner cartridge was installed, Therefore the counter did not cleared. Resolution: 1. Enter the PCU Diagnostic Mode, By turning off the printer and holding down the MENU and OK buttons on power up. (Release the buttons once you're in the PCU DIAG MODE) 2. Press the MENU button 14 times until the operator panel reads " Counter Display " 3. Press the MENU button and the BACK/C button at the same time, This will put the printer into the Feed Counter Clear Mode (Release the buttons once you're in the Feed Counter Clear Mode) 4. Press the up arrow 5 times until the operator reads " Toner Counter Clear " 5. Press the OK button, The operator panel will now display " Toner no " 6. Press the up arrow once and the operator panel will display " Toner yes". Now press the OK button and the green data light will flash to indicate that the clear process is complete 7. To exit the PCU Diagnostic Mode, By turn the printer off and then back on this will allow you to exit the PCU Diagnostic Mode Hope that helps. If it does not please let me know Ed
Jun 12, 2007 | OKI B8300 Laser Printer
OKI B8300 Laser Printer Logo
936 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
