Telescopes
Problem for Telescopes
Generic problem for all Telescopes
Sears UltraSoft 800 Water Softener LCD Dis...
By ronbigdog on Feb 07, 2008
My discharge hose end froze and water leaked at the water softener end thus spraying water over the timer board. The display was blank. I took the 2 circuit boards out and dried them. It seemed to function o.k. but the display was scrambled allowing me too see small regions of text only. I removed the LCD display from the front cct board and found water staining at one end of the cct boards gold pads(which connect to the rubber strip connected to the actual LCD). I cleaded the staining and rubber pads and now things are worse. How do you align these devices properly to make the LCD work again.
Solution #1
posted on Feb 07, 2008
Not Helpful)
yalmer
Rank: Wiz
Rating: 82%, 337 votes
You need to ask at radio shack or similar electronics store for some kind of gell that will connect the rubber strip to the display. These displays show the information that runs through the rubber strip(fiber optics, I believe?).
It is critical to get a near perfect connection between the two.
Also for cleaning, I would ask a tv repair man what kind of spray solution he uses to clean circuit boards.
Also, whenever you are dealing with electronics, there is a possiblility of causing static which can wipe out a programmed chip on one of the circuit boards. That is why some components that are ordered come in a static free plastic.
Was this helpful?
Yes
No
Popular Solutions for Telescopes
Questions and Unsolved Problems for Telescopes
Answer
Hello, im up in the air with a choice of three telescopes in my price point around $500. Maybe you... (More)
Answer
what is best choice for simple telescope
Answer
I have a broken elevation spindle, the little aluminum casting that passes through the plastic... (More)
Answer
connect pc to tv using vga. What button do I push to activate connection
Answer
i have a micronta electric powered zoom telescope 12x-40x-40mm cat. no. 66-203 ----- electric does... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Telescopes:
Top Telescope Experts
Rank: Guru Guru
Solutions: 3902
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Telescope Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
