Question about Whirlpool GEW9250 Electric Dryer
2 hyphens are lit up in the time left indicator
My dryer won't start since these 2 hpyhens lit up in time left indicator came on. If I turn the different indicators for normal, bulky items, etc, nothing happens. I just keep having those 2 lines on. What does it mean?
  • HelpMePls1 Mar 02, 2008
    We have the same problem with ours. The machine is not quite 3 years old. Any ideas anyone?
  • fluhart33 Apr 07, 2008
    As of last night I have the same problem. 2 little lines in the time column and a dim light in the heavy load ode. I tried unplugging dryer and I tried the reset button several times. Nothing works. Can anyone assist with this problem or do I really need to buy a new part?
I finally brought a repair technician in and those lines mean that the electronic panel is not responding. It supposedly has a 2 year warranty. Since I was out of warranty the part alone was $350.00. I broke down and just bought a new machine.
Posted on Apr 02, 2008
I'm having the same problem with my dryer. it's is 1 year old. Does anyone have any suggestions. lb
Posted on Apr 01, 2008
Dryer chirping along with the following: start button flashing, dry temp on high light lit, 56 on timer timed dry lit and dry time selector lit was on sensor dry when we left and turned off
Disconnect power or turn breaker off for about 5 minutes. This may reset the unit. Otherwise you have an eror showing and need to retrieve the error code. Google your make and model followed by error codes a d you should get a link to retrieve the codes.
Aug 08, 2016 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't start
If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Oct 21, 2012 | Whirlpool GEW9250 Electric Dryer
Malta dryer burner won't stay lit
usually a clogged vent or I've seem a coil go bad that allows it to light once but not the second time in the cycle
Feb 01, 2012 | Maytag Dryers
My laptop won't boot up. I tried to boot it up with Norton Bootable Recovery Tool, still same problem. I keep getting a black screen with a hyphen blinking on the upper left of the screen?
Most of the time this "hyphen blinking" means your hard drive is faulty. fingers crossed this isnt what has happened to your laptop.
try... turning off your laptop completely... turn it on and then immediately start tapping f10 at the top of your keyboard. tap tap tap taptap taptap taptap taptap taptap tap untill.......
you should get a option for "Vaio recovery environment", you should be able to go through this "built in" recovery and not lose any data.
good luck!
Aug 24, 2011 | Sony VAIO VGN-CS215J/W Notebook
My Canon iP1300 won't print, message says Ink Absorber is full and I am not too sure what do do?
Hi, please try doing this:
1. Turn off printer.
2. Retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
It is undertaken from service manual. I hope this helps.
Aug 20, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Dryer won't run, control panel lit, start/pause light flashing green, none of the buttons work. Checked door switch & both thermal fuses, all okay. Was thinking it was control panel, purchased and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Full water indicator lit continuously even though
Problem was a stuck float in the small water reservoir to the rear left of the unit.. Remove top and left hand side panel. Small reservoir can be seen at the bottom left. Remove small screw and slide off the cable assembly above. You should then see into the reservoir and the float. Clean float and reservoir and reassemble.
Feb 08, 2010 | Zanussi TC7114W Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
59 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
