Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Red screen tv is on,no picture,screen is red,picture comes on,colors are very dim,some colors non-exsistent,anyone or anything that is red is tough to see
  • daleplus3 Feb 26, 2008
    I called customer relations,not service,gave them the ser. #,they gave me a phone# of a repair shop they use in my area, 5 min. on the phone the tech. came out,told me it was the light engine,called Hitachi,they sent out the part free of charge,service tech. came back with the part, 1 hr. and $217.00 and my t.v. looks like new. you guys rock,thank you very much!! ( light engine sells for over $1500.00)
    President:
  • 4,402 Answers
Possible Light engine. Try calling Hitachi, usually they will be able to cover your parts, if you pay the labor, after a servicer has verified the LE is fubar. Call Hitachi and see what they can do for you. Just make sure you are really nice and polite, that always helps when you get the person on the other end to really want to help you.
or
poor connections on the back of the tv connecting to the tv, or you have the colours incorrectly connected.
Posted on Feb 07, 2008
  • Cary Farah
    Cary Farah Feb 26, 2008
    please mark my post as fixya!
    Genius:
  • 3,422 Answers
The only solution is to replace the two STK Ic's on the board and your problem will be solved.Get it fixed by a repairman
You can get the parts at www.ptscorp.com or www.partstore.com
Hope ur problem gets solve soon..
Goodluck,
Please don't forget to rate me as fixya..
  • 1 more comment
  • Priya darshan Feb 07, 2008
    hi the stk ic's look like this. The cost if replacing this component don't use cheap ones, there are a lot of
    inferior components on the market, you should pay approx $25 -$40
    However you can also give this a try:
    Do the reset test Disconnect the power cord for 4 hours. Then when you
    power it back up
    the internal soft codes will automatically reset to factory defaults.
    if this doesn't work u have to call a technician and get it repaired..
    Goodluck once again and please don't forget to rate me as fixya..
  • Priya darshan Feb 26, 2008
    Your Welcome.
    Thank you for using fixya.
Vizio tv prolems. TV comes on normal for about 10 seconds (bright w/ colors) then picture dims with a hissing sound from the electronics. Anyone has an idea of a repair video to watch.
The hissing sound is over current from a shorted component. you best bet is to call around and see if anyone can repair it. Ask price first because you might be better off just buying a new one.
Dec 28, 2014 | Vizio VO47L 47 in. LCD TV
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
Zenith TV has me seeing red.
The red gun in the picture tube itself is shorted on. You will have to replace the picture tube itself to fix the problem. Probably want to just buy a new set. Sorry!
Mar 16, 2010 | Zenith B25A10Z 25" TV
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a Magnavox 51MP392H/17 Rear projection TV. about 2 months ago the color start to merge into each other and showing double. I would cut the TV off...wait a few minutes then turn it back on and the...
yes its repairable
its a convergence circuit failure there are a couple ics and most likely some resistors that will need replacing and possibly a pico fuse
est 300 to 340 you mention only red and green though do you not have blue in your picture
id bet the blue is non exsistant and will need a blue liquid kit changed to correct that problem also
you might want to conatact a local servicer and give a model and ask them what they woud do both for then you can make a decision if you want to do it or not
Oct 31, 2009 | Philips Magnavox 51MP392H Rear Projection...
Color fading, orangy red, video adjustments don't fix.
if it is a tube type unit you may not find a new tube they are almost extinct ,
also, most tube malfunctions are caused by improper voltage, only a qualified tech should work on the high voltage section of a tube tv,,, it can kill you even if it has Not Been Plugged in for a whole year
re-post with the make and model number for further assistance
Apr 08, 2017 | Televison & Video
Phillips Magnavox 60 inch Projection Tv
That model is famous for having bacterial contamination in the CRT coolant causeing halos, and dim pictures with bad overall color issues. You can look into the lens of the CRTs when the set is laying and if the coolant looks cloudy or has any growth there you will notice it right away, and changing the coolant will restore color, clarity and brightness.
Jun 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Hitachi 61SDX picture got dim shows Code 3
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 17, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Sony KF-42WE610
Sound but no picture, tv will not turn off. Light goes red but a dim overall blue screen remains and fan is still running.
Nov 15, 2007 | Sony XL-2100U Projector Lamp for...
HCL4715W Rear projection "Red" color is dim
screen adjustment,remove front bottom cove and find the focus block the screens are also on the same block,if your not sure don't try.
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
