Migrating from two netgear hubs to 3Com Baseline swithch:
Two computers don't connedt. have changed wiring have tried different ports
Hello, am paul rutabingwa
to add computers on my network i installed a 3com 16 ports switch but failed to cnnect these computers to my network. note that my router is a linksys wireless - G 2.4 GHz
Posted on May 19, 2009
    Scholar:
  • 70 Answers
To connect 2 computers without a hub/switch you need to have a cross-over cable. Normally a network cable only uses pins 1, 2, 3 and 4 with pairs 1,2 and 3, 6 on both ends. A x-over swaps the pairs on one end.
Go to a computer store near you and ask for one. Don't pay more than $10.
If you can't find one or it is expensive, let me know and I'll make an adapter for you and just charge around $5 for the parts and shipping. My email is fixya@pcsports.org and put "X-over Cable" as the subject.
Jeff
Posted on Feb 09, 2008
3com don't telnet
Make sure its not blocked from the router settings and the corresponding port is open.
Sep 24, 2013 | 3Com Computers & Internet
Firmware update for 3Com 2952
Don't let the switch name fool you, HP calls it the HP 1910.
HP 1910 48G Switch Fixed Port Web Managed Ethernet Switches HP JE009A ABA
Technical Notes:
"The HP 1910-48G Switch (JE009A) was formerly sold as the 3Com Baseline Plus 2952 (3CRBSG5293) and may ship with this product labeling.SFP ports and copper ports work simultaneously, independent of each other to give a total of 52 Gigabit-capable ports."
Firmware download from HP:
My Networking HP Official Site
Jan 14, 2013 | 3Com Baseline Plus 2952 52 Port Gigabit...
Superstack 3 3848 reset at default
Hi ! I think this solution should be approached. Because this procedure is the same for switches 3Com and HP A-series with Comware OS.
1. Connect light blue console cable between a computer (serial) and the 3COM switch (RJ45 console port)
2. Open PUTTY or Xshell or HyperTerminal with a serial connection and the following settings (19200, 8, 1, N) If not connected may use 9600 or 115200 bps
Starting......
* 3COM 2928-SFP Plus BOOTROM, Version 119 *
Creation Date : Feb 3 2010
CPU L1 Cache : 32KB
CPU Clock Speed : 333MHz
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Mac Address : 002473959EC8
4. When "Press Ctrl-B to enter Extended Boot menu..." appears, press "CTRL+B"
Press Ctrl-B to enter Extended Boot menu...0
Please input BootRom password:
BOOT MENU
5. Press "7" to "Skip current system configuration"
1. Download application file to flash
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5. Modify BootRom password
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set BootRom password recovery
9. Set switch startup mode
0. Reboot
Enter your choice(0-9): 7
7. Press "Y" to skip the current config at next reboot
The current setting will run with current configuration file when reboot.
Are you sure you want to skip current configuration file when reboot? Yes or
No (Y/N):Y
Setting...Done!
8. Now Press "0" to reboot the switch
BOOT MENU
0. Reboot
Enter your choice(0-9): 0
9. The switch will reboot, allow it to fully boot this time
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Starting to get the main application file--flash:/S2900-CMW520-R1101P09.bin!...
The main application file is self-decompressing................................
.........................Done!
System is starting...
Configuration file is skipped.
User interface aux0 is available.
10. Press "Enter", you will not need a password to login.
Press ENTER to get started.
<3Com Baseline Switch>
#Apr 26 12:00:16:292 2000 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>: login from Console VMadmin.co.uk
%Apr 26 12:00:16:461 2000 3Com Baseline Switch SHELL/4/LOGIN: Console login from aux0
11. Now type "initialize" to delete the configuration file and reboot the switch once more, Press "Y" to accept reboot.
<3Com Baseline Switch>initialize
The startup configuration file will be deleted and the system will be rebooted. Continue? [Y/N]:Y
Please wait...
#Apr 26 12:00:33:537 2000 3Com Baseline Switch DEV/1/REBOOT:
Reboot device by command.
%Apr 26 12:00:33:641 2000 3Com Baseline Switch DEV/4/SYSTEM REBOOT:
System is rebooting now.
12. The switch will full start up again, this time completely factory reset.
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Startup configuration file does not exist.
13. Press "Enter", then enter the username "admin" and password "<blank>". Press "Enter" and you will be logged in.
Login authentication
Username:admin
Password:
#Apr 26 12:00:19:811 2000 this article is from VMadmin.co.uk 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>:admin login from Console
%Apr 26 12:00:19:981 2000 3Com Baseline Switch SHELL/4/LOGIN: admin login from aux0
14. If you type "summary" you will see all the switch details.
Amongst these details are the IP address of the switch. If you have DHCP on your network this switch is connected to it will receive one as in my case below, so I can now configure the rest via a web browser.
If not you can use the "ipsetup" command to set a static management IP and access via a web browser.
<3Com Baseline Switch>summary
Select menu option: Summary
IP Method: DHCP
IP address: 192.168.1.250
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.254
Current boot app is: flash:/S2900-CMW520-R1101P09.bin
Next main boot app is: flash:/s2900-cmw520-r1101p09.bin
Next backup boot app is: NULL
3Com Corporation
3Com Baseline Switch 2928-SFP Plus Software Version 5.20 Release 1101P09
Copyright (c) 2004-2010 3Com Corp. and its licensors. All rights reserved.
3Com Baseline Switch 2928-SFP Plus uptime is 0 week, 0 day, 0 hour, 1 minute
128M bytes DRAM
128M bytes Nand Flash Memory
Config Register points to Nand Flash
Hardware Version is REV.B
CPLD Version is 002
Bootrom Version is 119
[SubSlot 0] 24GE+4SFP Hardware Version is REV.B
15. Once you can access the web management page for the switch make sure you set a strong password for "admin" and store it in a secure encrypted location for next time.
16. Don't forget to save your new configuration! Otherwise the switch will be at factory defaults if the power goes off!!
Jul 24, 2017 | 3Com SuperStack 3 3848 48-Port Gigabit...
I work at a school and we are trying to connect 2 HP 3com Baseline switch 3952 together. however when I plug in my Cisco SFP modules into both the switches, neither of the ports light up and establish a...
1.what type of fiber is:SM (single mode) or MM (multi mode)?
2.what type of sfp? 1550 or 1310 if is SM, how many conectors and what type of conectors
3.in 3com usualy u dont need to make a port anouncemant as u need in cisco so if the sfp are ok, i mean if they are pairs and the fiber is same type should work, second problem : sometime the cisco sfp(when is not original from cisco) got problem in other brands hapend to me whit zyxel sw,
so give me more data and i will help you
thanks
Sep 22, 2011 | 3Com Baseline Plus 2952 52 Port Gigabit...
3Com Baseline Switch 2024 - Switch - 24 ports duplex light blink continusly
Is it hsappening with all the 24 ports or with some ports ?
Might be an indiacation towards the duplex mismatch.
are you getting CRC errors on the interfaces ?
Dec 05, 2010 | 3Com Baseline Switch 2024 - Switch - 24...
Hub power down
the switch contacts have probberly arked and burnt away, u/s new switch needed
Jul 06, 2010 | 3Com (3C16593BN) 24-Port Ethernet Hub
How do i Reset or break in to get reset my password on 3Com 2948 Baseline Switch 48Port SFP Plus
The resetting of the password requires the installation of a console cable to the console port.
Be sure the terminal emulator program is set to VT-100 management using compatible, 38400 baud rate, no parity, 8 data bits and Console connection one stop bit.
Use the included cable, or be sure that the pin-out complies with a standard null-modem cable
Once the cable is connected, reboot the switch. Type a Ctrl/C until you enter the failsafe mode. This will be denoted with the prompt: “CFE>”
At the prompt execute the following commands:
CFE> passwrd
CFE> reset -sysreset
At this point the password has been reset.
Jan 20, 2010 | 3Com Baseline Switch 2948-SFP Plus 48-Port...
Computers & Internet Logo
307 people viewed this question
Alun Cox
David Payne
David Payne
